Here in central Arkansas, the weather is decent, but that doesn't mean it doesn't rain and make things otherwise unpleasant weather-wise.
I'm in central AR also, where are you?
In other news, rode 200+ miles from the Mississippi Delta to Little Rock, AR, where the Connie will set up permanent residence.
The bike will be much more entertained with the Ozarks beckoning nearby.
Cold rainy weather this weekend so I did some mods. Installed my Garmin Zumo on the Concours.
You be careful with that. I realize that not everybody has the same problem as I do, but many do. That GPS is pretty low....if you have any close calls while your head is down and locked on something on that screen....take it as a warning to move it higher on either handle bar or wherever. If you just tell yourself that it won't happen again and you'll just be more careful next time....you may not get to see the next time.
OK, I'm done preaching.
I purchased a shelf that mounts above the instrument cluster and right in the center of the bike. Purchased the shelf from Kawasaki Police. It is mounted high enough that I never take my vision off of my path of travel and it doesn't obscure my vision.
