Author Topic: What did you do to your Concours today?  (Read 1396986 times)
« Reply #2160 on: May 15, 2016, 05:31:32 PM »
New rear tire and greased the splines on the drive shaft.
« Reply #2161 on: May 15, 2016, 06:14:26 PM »
Finished the fuse block install and swapped the ZX/GP forks to the 09. Got halfway through the display control mod.
Offline Sgt Mac
« Reply #2162 on: May 15, 2016, 07:04:46 PM »
Added a dual usb port on the left side of the dash. What a pain in the ass.
Offline turbojoe78
« Reply #2163 on: May 17, 2016, 06:37:13 AM »
Did MY first oil change, (dealer did very first at 620 miles) needed to use a pair of channel locks to get the oil filter off.
Also changed the rear diff lube over to Mobil 1 full synth 75W-90.
Offline DaddyFlip
« Reply #2164 on: May 18, 2016, 06:57:40 PM »
Mailed my ECU to Shoodaben for the Decel flash.
2001 ZR-7s "Ol' Red"
1995 FXDWG
« Reply #2165 on: May 18, 2016, 08:04:12 PM »
I use the same type of gear lube. The GM stuff.
My bike stuck like glue with the new Avon 3D Ultra. I only rode it one day in Arkansas, but it felt awesome.
I picked up that rear tire up from Motorcyclecloseouts for $107.
Offline Eupher
  • U.S. Army, Retired
« Reply #2166 on: May 24, 2016, 04:55:48 PM »
Installed the ECU after Steve's flash. Rest of the writeup at Reply #268:
http://www.zggtr.org/index.php?topic=20462.255
2012 C14 Arabian Candy Red
2003 Honda 919
1981 Suzuki 650E
1965 Honda S90
Offline ManWorkinghere
    • Avatar database
« Reply #2167 on: May 26, 2016, 01:36:50 PM »
Do you have a C-14 then?
I originally put a port in my '01.  My writeup is on Blogger.com.
This winter, I replaced the charging port I had and the USB plug with a dual-port USB port in my C-10.  Rather easy for me.  C-10's have ready access to the dash.
http://c10mods.blogspot.com/
« Reply #2168 on: May 26, 2016, 03:25:09 PM »
Since this thread is in the C14 forum.... you can be fairly sure he does have one :)
« Reply #2169 on: May 26, 2016, 03:37:53 PM »
The picture kinda gives it away as well...
Offline Sgt Mac
« Reply #2170 on: May 27, 2016, 12:44:55 PM »
I do, 2011 model year. The left side of the dash has a blank spot where you can drop a power port, the metal bracket behind it has a square hole, smaller than the double usb I had on hand. Pain in the butt was enlarging the hole in the bracket to allow it to fit.
« Reply #2171 on: May 27, 2016, 01:14:04 PM »
Washed it, believe it or not.
« Reply #2172 on: May 27, 2016, 01:24:05 PM »
 :yikes: Without protection?
« Reply #2173 on: May 27, 2016, 03:25:28 PM »
Yep, no sunburn lotion or mosquito repellent.   I got sunburned, but no mosquitoes.
Offline Ron Dawg
  • a/k/a ron203
« Reply #2174 on: May 27, 2016, 07:48:36 PM »
Put the Murph's dual horn kit wires that I extended 13" for use on the C-14, into flex tubing conduit under the dash and moved the relay behind the intake snout to make the wiring nice and clean looking when you look down in the fairing.
2014 C-14 Red
Offline Hooligan
  • Country: za
  • never assume, get the facts
« Reply #2175 on: May 28, 2016, 01:21:31 AM »
No offence Jim, but there is a reason we call the English "Red necks" in the RSA. During the Anglo-Boer war, the sun used to burn their necks red with their short haircuts. Having a pale white skin here in SA is not a good thing.
2012 K1600GT
2009 ZX14
« Reply #2176 on: May 28, 2016, 03:26:03 AM »
« Reply #2177 on: May 28, 2016, 04:39:15 AM »
« Reply #2178 on: May 28, 2016, 05:39:49 AM »
You had to fight them too? When we kicked them out of the colonies we called them lobsterbacks. No offence.  :)
sailor_chic
« Reply #2179 on: May 28, 2016, 06:39:51 AM »
And now back to our main topic....
I installed a new set of PR4GT's on my bike yesterday, and an oil change. I used Rotella T6 and a Bosch filter. Is that a good oil to use? (haha) Getting it ready for my summer road trip next month.
