Author Topic: What did you do to your Concours today?  (Read 1385911 times)
Offline Eupher
  • U.S. Army, Retired
« Reply #3460 on: May 17, 2021, 10:51:04 AM »
Cleaned it up after a 705 mile 2-day swoop down into Mississippi and back again. Lotsa bug guts. BTW, microfiber cloths work great in cleaning the windshield and helmet faceshield.
2012 C14 Arabian Candy Red
2003 Honda 919
1981 Suzuki 650E
1965 Honda S90
Offline SVonhof
  • 2009 C14
« Reply #3461 on: June 21, 2021, 08:24:02 AM »
Got home yesterday after a 5 day trip with buddies. 1600+ miles and the last 2 days was in some heat (it was 107 out when I got home).
I have a right front fork seal leak that showed up the first day. I had previously used a SealMate to get it to seal up, but I guess it is time to do it right.
Scott
Offline tomp
« Reply #3462 on: July 12, 2021, 07:32:59 PM »
FWIW, I bought a '17, last October, that had been purchased new in '19, now with 641 miles on it.  It's that Beautiful Blue color.  With Corona, work and weather,  I've only been able to get a thousand miles on it.    With things finally improving, hopefully it will be my work commuter soon.    Traded an '18 Slingshot for it.  It was fun, but not a Concours.    Hope all are well and enjoying the summer with their 14's...  tomp
Living in the Texas Coast...
Offline Mr2U
« Reply #3463 on: July 13, 2021, 11:46:08 AM »
Got my frame sliders on, and
if its a Fat Ninja, might as well have Ninja on it.
Offline kzz1king
« Reply #3464 on: July 14, 2021, 01:40:01 PM »
Installed new tires, put a new battery in front TPMS, changed  diff fluid. Checked pads and called it good.
2010 CONCOURS
1974 Z-1
Offline Pilgrim
  • '12 Black
« Reply #3465 on: July 21, 2021, 11:56:40 AM »
New tire pressure sensors, front and rear, installed by dealer under KPP extended extended warranty.  New front tire installed while wheel was off for sensor replacement.   KPP warranty paid for itself, which expires in two months.
Offline speedracersworld
  • 817-821-0448
    • Speedracersworld
« Reply #3466 on: August 05, 2021, 04:37:39 PM »
Installed a New MRA Vario Windshield. Love the extra airflow on these Hot Texas Summer Days.
There's more to Life than the Mainstream Media or "Reality" TV! Question Everything!
2008 Atomic Silver C-14
« Reply #3467 on: August 05, 2021, 04:46:45 PM »
Yep.  I cut several inches off my stock screen and installed an MRA X-Screen on the top of it, for use during half the year.  TONS of adjustability options now (main screen height, X-screen angle and height).  Made a HUGE difference in additional airflow and comfort in hot weather.  I did this way back when someone had overstock on stock C14 screens cheap, so I bought one and use that newer one for the other half of the year (when it is cold), and move the X-Screen to be on top of that, too :)
Offline jdaugh
« Reply #3468 on: March 18, 2023, 06:28:18 PM »
Sailor chic, did you ever find anyone in FL with a KDS? I'm looking for someone near/between Jax and Daytona. Actually in the middle of those but also inland a bit: Welaka. I need to get a passive chip registered as a backup for the active transponder for my 2010 c14. Right now I have only the active transponder. Its passive chip was lost and I got one from another fob. Apparently, registering the passive chip doesn't require any original ID code or anything like the active transponder does.
Maybe the dealer will do this for a reasonable price. I'll check Monday. But it would be great if I could save miles and/or dollars and give the dollars to someone who got a KDS instead.
Offline deepseamdv
« Reply #3469 on: March 19, 2023, 09:50:12 PM »
Contact Steve Sefsick, he has the KDS3 system and is in FL. shoodabenengineering12@gmail.com
Offline jdaugh
« Reply #3470 on: March 20, 2023, 08:20:45 AM »
Thank you deepseam, I did! He's mostly just doing ECU flashes for now but he directed me to an Ed. I think he said Ed does clones, but I'll also reach out to the HarleyGuy you mentioned in this post:
http://zggtr.org/index.php?topic=25583.0#new
Offline Big Red
« Reply #3471 on: March 20, 2023, 12:11:07 PM »
Swapped all of my tall person accessories from my old 2010 to my new 2010.
Offline deepseamdv
« Reply #3472 on: March 20, 2023, 07:01:16 PM »
jdaugh
Ed and harleyguy are the same person.
Offline Deathwish
« Reply #3473 on: May 05, 2023, 02:37:45 PM »
Swapped out my Sargent seat for a Top Sellerie. Very nice quality and very comfy so far. Needed something taller for my hips.
Offline Pilgrim
  • '12 Black
« Reply #3474 on: November 13, 2024, 05:15:17 AM »
Winter hibernation prep.  Oil and filter change. Filled the tank. Plugged in the battery tender.
Offline Jethrobolas
« Reply #3475 on: April 16, 2025, 04:45:27 PM »
Just finished a valve check/adjust. Put Delk headers on while it was in it's exploded state. Did the coolant, plugs, brake and clutch fluids too. 2 weeks start to finish with ordering parts, used Murphs for the gaskets, summit for the shims. Worked on it sunday's primarily, putting an hour or two in a couple times during the week after work. Probably 25-30 hours total on the project, just taking my time.
Job is done, have ridden 10 minutes with the headers on, not sure I'm happy. Been running Steve's full system flash for almost a year, but didn't swap the stock headers for the Delk until the valve check/adjust I just performed. Just been running the slip on. Nice noticable gains down low, a little more peppy throughout the rev range with the stock exhaust and  with slip on.
Admittedly, I haven't really put but 7 miles on it but it feels unflashed now at the low end of the rev range. I packed the reducer into the pipe per Shoudabeen instructions. It just doesn't seem to have recovered the 18 or so ft/lbs around 3500+.
I may wind up putting the stock tubes back on before heading back to the Sierra Nevadas because the low end response and pull from those little tubes was quite nice. I may not even be able to tell it's got 5-10 more HP when I'm screaming it, so I feel like it may not be worth the trade off. I'll see how I feel after putting a few more miles on.
Update.. rode it a bit more and it does seem to have retained the lower end grunt. Nice work, big thank you to Shoudabeen Steve!!
« Last Edit: April 19, 2025, 01:14:09 PM by Jethrobolas »
