Author Topic: What did you do to your Concours today?  (Read 1393483 times)
Offline mikeeitup
« Reply #3260 on: November 13, 2018, 11:28:54 PM »
Just finished my second TPMS battery change (but this time without fking everything up). Very pleased with the work done. At least this sensor is in excellent condition to start and has the shock absorbing spring unlike the last sensor. Remember, ALWAYS replace the dang rubber gasket!!!! My last one leaked like a sumbitch because I was too cheap to do it right!
~Mike~
~2012 Black Connie~
« Reply #3261 on: November 14, 2018, 07:06:50 AM »
Maybe you should plastic wrap up the bike or something?
saran or glad?
Sounds like the Kirkland brand is the way to go. Except that mice chew through plastic wrap.
I do hate to use poison on the lil critters but I hate having my bike eaten MUCH more.
Offline kzz1king
« Reply #3262 on: November 14, 2018, 08:54:31 AM »
I use the bucket type traps with RV anti freeze in them. Kills them in bunches. I keep poision out as backup. I have acres of tall grass around me so it is a constant battle. I think I am winning though!
2010 CONCOURS
1974 Z-1
« Reply #3263 on: November 14, 2018, 12:50:25 PM »
Installed 2 PIAA Sports Horns.
Bitchin' dude. Are they loud?
Offline Hexrays
« Reply #3264 on: November 14, 2018, 12:54:30 PM »
They sound like the old Cadillac horns. Kinda funny coming from a bike.  :D
2014 C14, Risers, Cee Bailey Windshield, Givi Top case, GTR Ultra Series LED's, PIAA Sports Horns, Kuryakyn Passenger ISO Pegs.
Offline SVonhof
  • 2009 C14
« Reply #3265 on: November 14, 2018, 05:41:53 PM »
I changed the oil (engine and final drive), cleaned her up and also ordered a Go Cruise (finally).
Didn't ride it though as I had other things to finish off.
Scott
Offline kzz1king
« Reply #3266 on: November 15, 2018, 07:13:32 PM »
Looks like a clean install. Any wiring upgrades needed?
Wayne
2010 CONCOURS
1974 Z-1
Offline Hexrays
« Reply #3267 on: November 15, 2018, 08:26:11 PM »
Wayne
No special wiring. Just used a piggyback spade connector to run the second set of wires to the other horn.
Offline okrider
  • Dora: '11 Black
« Reply #3268 on: November 25, 2018, 05:18:31 PM »
Paging Man of Blues..
Riding around today, noticed oil smell from the exhaust. Some digging points me towards the camshaft position sensor. A little bit of searching later, I found out about MOB's seals sold on Murph's. I've read multiple threads on the subject. If there's a good thread that has step by step directions, if someone can link it, I'd appreciate it. It seems like I can reach in there with a box wrench and remove the sensor bolt simply by loosening the left fairing (the one with the fins).
Mainly trying to confirm I don't have to remove the valve cover and can get by with just swapping the seal on the sensor and bolting it back on.
Thanks,
OK
Offline kzz1king
« Reply #3270 on: November 25, 2018, 05:41:14 PM »
Got it up on the lift. See if I can make the horn work again.
2010 CONCOURS
1974 Z-1
« Reply #3271 on: November 25, 2018, 08:22:45 PM »
I think mine is also now dripping oil or something on the exhaust manifold, too.  I have noticed over the past several months, a burning smell after parking.  It is getting worse.  Sometimes it does smell like oil, other times more like plastic or even wood at times.  Quite bizarre.  I have even looked around with a flashlight and never find anything.  Still ignoring it for now :)
Offline okrider
  • Dora: '11 Black
« Reply #3272 on: November 25, 2018, 09:00:40 PM »
Looking at it from the front with a flashlight, the left half of the engine is stained with oil which leads me to think it's the left o-ring that is leaking. I recently did my first oil change since purchasing the bike and used Rotella. I'm thinking the different viscosity or switching to synthetic (assuming PO used dinosaur oil), made it easier to leak.
« Reply #3273 on: November 26, 2018, 06:56:19 AM »
Weather was nice this weekend. About 75*-78* and clear, so I invited my nephew and took both Connie's out for some exercise.        :thumbs:
Offline Poseidon
« Reply #3274 on: November 26, 2018, 07:42:24 PM »
I’ve gotten that burnt wood smell a few times. (actually, not even burnt. Just hot wood that is about to start burning) Kept thinking maybe I picked up a stick or something in or near the head pipes. I’ve looked and looked but never found anything. It is a little disconcerting pulling into an attached garage and having a smell like something is about to catch fire.
2017 Concours 14
2016 Victory Magnum
2013 M109R
« Reply #3275 on: November 26, 2018, 08:09:20 PM »
LOL!!  Thank God I am not losing my mind.  If it were only once, I would dismiss it as a leaf or something.  But it has been multiple times.
Offline Poseidon
« Reply #3276 on: November 27, 2018, 04:30:34 AM »
Same here. Puzzling.
2017 Concours 14
2016 Victory Magnum
2013 M109R
« Reply #3277 on: November 27, 2018, 12:42:16 PM »
I've had the same experience.  Could be the cam sensor seal leaking down on to the exhaust but not enough to really worry about.
Offline Poseidon
« Reply #3278 on: November 27, 2018, 04:10:05 PM »
Is that seal made of wood?
2017 Concours 14
2016 Victory Magnum
2013 M109R
« Reply #3279 on: November 28, 2018, 05:49:35 AM »
Of course not, silly boy, but there aren't any leaves and such under the covers.  What else could it be?
