Author Topic: What did you do to your Concours today?  (Read 1393376 times)
Offline turbojoe78
« Reply #2060 on: April 14, 2016, 10:40:51 AM »
Made Knob keys for my saddle bags using Bragg's Apple Cider Vinegar bottle caps like Bud Callaghan from this thread,
http://www.zggtr.org/index.php?topic=3602.30
And modified my gas cap so it can be closed without using the key following the instructions of Fred Harmon here,
http://www.pbase.com/fredharmon/gascapmod
« Reply #2061 on: April 14, 2016, 12:44:11 PM »
New reservoir project complete! I am amazed how dark the clutch fluid was when I changed it. <2 years old and 31,xxx miles. Glad I changed it.
Did you have any problems bleeding the clutch? I did it once using a MityVac and it was a b***ch. Just wouldn't flow. It's long bast time to do it again but the first experience makes me what to procrastinate even more then my normal nature.
« Reply #2062 on: April 14, 2016, 07:11:56 PM »
I bought her a younger sister
09 with 10,000 miles
Offline Deziner
  • Phoenix
« Reply #2063 on: April 15, 2016, 02:30:07 AM »
^^^^Nice!
Offline PeteTN_zgtr
« Reply #2064 on: April 15, 2016, 03:52:15 AM »
Had a productive day yesterday on my 2012 C14. Installed a Classic Industries hitch & a removable rack that attaches to the hitch, Now I can carry my tent & camping  gear on it. Also replaced the narrow stock front footpegs with Kuryakyn ISO footpegs, They are much wider & give much more support to the bottom of your feet.
I like the pegs. Do you have part numbers? I've browsed through the Kuryakyn catalog before and it's lengthy. The arch of my feet do get sore at times. Nice idea!
« Reply #2065 on: April 15, 2016, 04:56:40 AM »
Washed the bugs off of her and then took a long ride and reapplied the bugs.    :D
sailor_chic
« Reply #2066 on: April 15, 2016, 06:32:45 AM »
No problems at all bleeding any of the fluids. I used a Motion Pro bleeder. This made the project go well.
« Reply #2067 on: April 15, 2016, 06:47:56 AM »
Hmmm, works like speed bleeders which I've used on other vehicles. I was going to buy speed bleeders for the C14 but this looks better, just have to buy one. I'll give it a try. Thanks.
Offline tweeter55
  • Ride Hard...Ride Safe
« Reply #2068 on: April 15, 2016, 07:16:58 AM »
Wash...Rinse...Repeat
sailor_chic
« Reply #2069 on: April 15, 2016, 07:53:41 AM »
Heres what I purchased.
http://www.amazon.com/Motion-Pro-08-0143-Hydraulic-Bleeder/dp/B000MXW2EM?ie=UTF8&psc=1&redirect=true&ref_=oh_aui_search_detailpage
« Reply #2070 on: April 15, 2016, 08:21:46 AM »
« Reply #2071 on: April 15, 2016, 09:12:38 AM »
I use the same bleeder, it works great. I use it on all of my vehicles.
[smg id=658]
I just ordered one. Lots of bike work coming in a few weeks. Changing all the fluids will be one of the jobs. Hopefully changing the exhaust with a new flash will be another (oh boy oh boy oh boy...  :P)
« Reply #2072 on: April 15, 2016, 03:24:00 PM »
sailor_chic
« Reply #2073 on: April 15, 2016, 03:57:00 PM »
My recommendation, for what whatever that worth. Take the bleeder all the way out and put a couple wraps of teflon tape on the threads and then reinstall. I noticed micro bubbles when doing my clutch. I did the tape and the bubbles went away.
« Reply #2074 on: April 15, 2016, 04:08:29 PM »
.....but if I take the bleeder out won't I let air in or fluid out?
« Reply #2075 on: April 15, 2016, 06:29:07 PM »
I throw this thing around like a 100 cc dirt bike. Just loving it. 8)
 8)
Offline kzz1king
« Reply #2076 on: April 15, 2016, 06:43:40 PM »
I think if any air entered it would come out the first time you pumped the brakes. Losing a little fluid should not be a big deal. I know I have had trouble using the same bleeder because of the air leaking around the bleeder. Going to give it a try.
2010 CONCOURS
1974 Z-1
AlbertaDoug
« Reply #2077 on: April 15, 2016, 09:34:44 PM »
Install new EBC XC rotors, took out the pads( new shoes last week -less than 500m on them) and washed the callipers with soapy water. Engine and shaft oils.
Just waiting for the lock tight to set up then off to Some twisties tomorrow.
 8) 8)
« Reply #2078 on: April 16, 2016, 06:33:21 AM »
 8)
Missouri?
« Reply #2079 on: April 16, 2016, 07:12:33 AM »
Me too
No way! You're going to FINALLY change out that fluid?   ;)
