Author Topic: Mineral Spirits for carb level?  (Read 6719 times)
Offline kzz1king
« on: January 27, 2012, 01:46:55 PM »
I am going to check my fuel levels. When I put my 2 minute mod in I used something other than das but cannot remember what. Got the idea here though. Anyone know? Thanks
Wayne
2010 CONCOURS
1974 Z-1
Re: Mineral Spirits for carb level?
« Reply #1 on: January 27, 2012, 02:54:43 PM »
might ask Bubba Steve, but he and I use gas,,,,
you need something with the correct specific gravity, close to gasolene
I suggested once to use IsoHeet or Heet drygas additive, because it is safer, and also won't require cleaning the carbs afterwards.
I don't like mineral spirits, to me it's a contaminant.
jmho
Offline kzz1king
« Reply #2 on: January 27, 2012, 03:51:30 PM »
Thanks, not sure what it was and I thought I heard it from Steve but I have a memory only a mother could trust.  Gas has a specific gravity of .739 and alcohol has .802.  What I don't know is if that is close enough. Just hate to mess with gas in the shop during the winter with the furnace and all.
Wayne
2010 CONCOURS
1974 Z-1
Offline Bmcush
« Reply #3 on: January 28, 2012, 08:58:35 PM »
SISF IIRC does use something other gas to set float levels, just cant recal what it is
Offline The Other Brian
« Reply #4 on: January 29, 2012, 01:53:21 PM »
I would agree. I seem to recall him posting that he used mineral spirits.  I did a search but did not comeup with anything.  It was probably before the Crash of 2011.  Perhaps he will see this and set us straight.
Coon Rapids MN
2010 FJR 1300
« Reply #5 on: January 29, 2012, 02:12:40 PM »
I'll send him a note...he should be along shortly.... ;)
Offline Steve in Sunny Fla
    • Shoodaben Engineering
« Reply #6 on: January 29, 2012, 02:55:00 PM »
I use de-scented mineral spirits with tcw3 oil in it for color. No issues on contamination, because I check levels on a dedicated test stand, then blow the carbs out with compressed air before the ship or get installed. HTH, Steve
Offline Boomer343
« Reply #7 on: January 29, 2012, 04:01:02 PM »
Mammas and Pappas did a song about that called "This is Dedicated to the  Carbs I Love"
Offline kzz1king
« Reply #8 on: January 29, 2012, 06:47:24 PM »
Thank you gentlemen, now to find some tcw3.
Wayne
2010 CONCOURS
1974 Z-1
Offline snarf
« Reply #9 on: January 30, 2012, 06:00:21 AM »
Walmart is were I get mine.
2002 Conc
1986 Conc "The spirit of COG"
Offline Mettler1
« Reply #10 on: January 30, 2012, 07:37:22 AM »
   +1 on Walmart  Super Tech TCW-3 Gal. When I bought mine 18 mos. ago it was around $12
Offline kzz1king
« Reply #11 on: January 30, 2012, 11:48:29 AM »
Thanks guys, Walmart it is. Some of you add a teaspoon of the stuff every fillup?
2010 CONCOURS
1974 Z-1
Offline Mettler1
« Reply #12 on: January 30, 2012, 12:22:14 PM »
  If I run 200+ miles before a fillup I add about 2 ounces. 100+ 1 ounce. I found some cheap cough syrup bottle that fit in the right fairing pocket for trips. Bottle goes in a ziplock bag in case of a leak. That could be messy!! If you miss a fillup or two, no problem. My bike parked at home always has a full tank of gas.
« Reply #13 on: January 31, 2012, 07:52:06 AM »
  If I run 200+ miles before a fillup I add about 2 ounces. 100+ 1 ounce. ...If you miss a fillup or two, no problem. My bike parked at home always has a full tank of gas.
I can see doing this for storage, long term, but if you ride regularly, and cycle fuel thru constantly, it's kinda silly no? Occasional use, maybe, but every fillup?
I mean adding 2 oz of oil to 6 gallons of fuel, is basically running a 2 cycle premix in a 4 cycle engine...
Just saying, and I am sure anyone following you on the road appreciates the aroma. ;D
« Reply #14 on: January 31, 2012, 11:08:46 AM »
But But BUT that's what Steve does right?  ;)
Offline Mettler1
« Reply #15 on: January 31, 2012, 02:09:53 PM »
    Damn straight, Mister!! ;D
Offline Mettler1
« Reply #16 on: January 31, 2012, 04:01:30 PM »
     I'm sure they do! I use a great deodorant. 8)
« Last Edit: January 31, 2012, 06:04:18 PM by Mettler1 »
Offline Mettler1
« Reply #17 on: January 31, 2012, 04:31:39 PM »
   THIS will absolutely put an end to all discussion about the use of TCW-3 in our ethonal fueled carburated Concours!! ::)  Read this:
      http://hhrchevyfamily.19.forumer.com/a/using-2cycle-oil-in-gas-wal-mart-tc-w3_post7688.html
       In my next feature I will end ALL oil thread discussions!!!!!
« Reply #18 on: January 31, 2012, 08:00:07 PM »
If I'm on a trip, tank over tank, I'm not running tcw3. But my bike is a "recreational vehicle" so it sits alot, and when it's sitting it has TCW3 in it. One time last year I expected to be riding, and didn't spike the tank; then the bike set in the hot shop during the summer and suffered severe dehydration (evaporation). end result, pilot circuits clogged, and I had to pull the carbs tho clear the pilot circuits. i've always kept TCW3 in the voyager, same carbs, and it has never had an issue. Steve
Offline throb
« Reply #19 on: February 01, 2012, 04:40:12 PM »
My question;  I run ethanol free gas in everything possible, having a choice of three local stations that sell it.  The only exception is when I may be out of the area and need fuel.  Is there any benefit to adding tcw3 to this fuel?
