Author Topic: Mineral Spirits for carb level?  (Read 6737 times)
Offline Mettler1
Re: Mineral Spirits for carb level?
« Reply #20 on: February 01, 2012, 05:58:49 PM »
   One of the reasons I started using TCW-3 is I had a "jerkiness" for yrs when crusing at about 35mph in suburban streets even after a good carb cleaning, Steve's 2MM and T Cro's Stick Coils. So I did a compression check and had 3 cyls at 190 psi and #2 cyl at 170 psi. A teaspoon of oil in that cyl bought the pressure upto 185 psi. Looked like a ring problem.
    Talked to "guru" Steve and he suggested maybe a stuck ring due to carbon. He suggested using TCW-3 might remove carbon and free up the ring. So after using it for about 3 months one day I noticed the "jerkiness" was gone. Did a compresssion test and all cyls were back to normal psi.
    The claim is that it removes-reduces carbon. Really don't know for sure but I like the results in a smoother running bike.
Offline kzz1king
« Reply #21 on: February 01, 2012, 07:47:18 PM »
OH NO! I inadvertently started an oil thread.  New ground for me.
Wayne
2010 CONCOURS
1974 Z-1
Offline Mettler1
« Reply #22 on: February 01, 2012, 09:37:15 PM »
Wayne
 Gee Wayne, I don't think it was intentional. We will just pretend it didn't happen. :deadhorse: :deadhorse: :deadhorse: ;D
