Author Topic: Do I have a transmission problem on the way?!  (Read 5516 times)
Offline Slideways
« on: April 09, 2013, 07:35:03 AM »
Here is what happens. Shift from second to third and the normal mechanical 'feel' throught the toe of the boot is not the same and the gear does not engage. Thought maybe I was unknowingly still slightly pulling up against the shifter but that is not the case. The result is a false neutral. It is not happening upon every shift but does seem to be happening more often. I am aware of it and look for it every time that shift is made and a second try before the clutch is engaged gets it into third every time. Any thoughts would be appreciated.
If it can't be fixed with a hammer you can sure as hell teach it a lesson.
2008 ABS, Area P full system, Power Commander, Skene Design, Canyon Cages (personally tested, don't ask), Sargent low saddle, Tamer throttle tube, Cee Bailey Euro Tour, bar risers, Throttlemeister, Tech Spec,
Offline Spanky
Re: Do I have a transmission problem on the way?!
« Reply #1 on: April 09, 2013, 07:58:45 AM »
Not much help, but I have never experienced that and I can't recall seeing any other posts like this. My guess would be you need to have a mechanic look at that. I am sure some of the mechanically knowledgeable people on here will have more specific ideas of what may cause that. Good luck and I hope you get that fixed soon.
« Reply #2 on: April 09, 2013, 08:02:45 AM »
+1 and I hope it's under warranty.
Offline Boomer
« Reply #3 on: April 09, 2013, 08:05:56 AM »
If it's an upshift, the first thing to do is adjust your gearchange lever down a little.
These gearboxes are quite sensitive to having the gear lever adjusted correctly.
It's an easy thing to check and fixes most peoples gearbox "feel" issues.
« Reply #4 on: April 09, 2013, 09:21:23 AM »
Also pull the lever off the shaft and "lightly" apply some waterproof grease.
Offline chi-gpz1100
  • Moderator
« Reply #5 on: April 09, 2013, 10:00:06 PM »
Make sure the shifter linkage rod isn't bound up.
« Reply #6 on: April 10, 2013, 10:26:50 AM »
The transmission on mine has been silky smooth and flawless. I would suspect adjustment as well.
Offline McJunkie
« Reply #7 on: April 10, 2013, 03:49:41 PM »
Kawasakis were notorious for this in the past but haven't heard of this problem lately. It comes from not fully shifting into gear when up-shifting. After time, this would end up rounding off the dogs and eventually causing the bike to go into gear then pop out or into a false neutral.
