« on: April 09, 2013, 07:35:03 AM »
Here is what happens. Shift from second to third and the normal mechanical 'feel' throught the toe of the boot is not the same and the gear does not engage. Thought maybe I was unknowingly still slightly pulling up against the shifter but that is not the case. The result is a false neutral. It is not happening upon every shift but does seem to be happening more often. I am aware of it and look for it every time that shift is made and a second try before the clutch is engaged gets it into third every time. Any thoughts would be appreciated.
Logged
