Author Topic: Bled front brakes, now no brake light - WTF???  (Read 3264 times)
Offline John_Atkinson
« on: August 23, 2012, 07:51:56 PM »
hi all,
just finished installing my SpeedBleeders all around and bled brakes and clutch. Thinking that I'd be able to go for a ride tomorrow, I fire up Zeke and, while checking all my lights, find that the front brake does not activate the rear brake light.
The only thing I can think of is that on one occasion, I overfilled the master cylinder and when I reinstalled the diaphraghm and cover, some fluid overflowed. I'm wondering if maybe some fluid got into the brake light switch and has shorted it out?
Thoughts?
John Atkinson
'91 Connie "Zeke"
217,000 km and counting...
Offline Outback_Jon
Re: Bled front brakes, now no brake light - WTF???
« Reply #1 on: August 23, 2012, 08:06:43 PM »
Take the switch off (one screw, if I remember correctly) and spray it with some electrical contact cleaner.  Work it a few times and see what happens.
NOTE: The switch seems to work "backwards", in that when the button on it is "OUT", the brake lights should be ON.  When it is pressed "IN", it breaks the circuit and the brake light should be off.
« Reply #2 on: August 23, 2012, 08:08:25 PM »
When you apply the front brakes listen closely can you hear the tiny little micro switch clicking? Try washing is out with a spray of WD40. Perhaps the wires came unplugged from the switch whilst you were working on the bleeding.
Offline bouts
« Reply #3 on: May 05, 2014, 06:11:42 PM »
Bumping this thread, I just developed the same problem.  Where is the switch located and how do you get at it?  TIA
Offline tweeter55
  • Ride Hard...Ride Safe
« Reply #4 on: May 05, 2014, 06:34:07 PM »
Stupid question here...did it work before you bled the brakes?
« Reply #5 on: May 05, 2014, 07:39:25 PM »
Right there in the master itself, when you pull the lever it works the micro switch itself.
Offline bouts
« Reply #6 on: May 05, 2014, 08:15:00 PM »
Thanks will check tomorrow after work  Yes it was working prior
Offline bouts
« Reply #7 on: May 06, 2014, 07:00:13 PM »
Easy fix, a disconnected wire!!  on to the next niggly problem!!
Offline dboogie2288
    • Beginnerbikers.org
« Reply #8 on: May 08, 2014, 02:50:32 PM »
haha! my 86 did the same thing! and I had even ordered a new switch from murph! gotta love the easy stuff though.
Offline bouts
« Reply #9 on: May 08, 2014, 07:06:43 PM »
Lol  My new switch came in today
