Author Topic: Throttle Pull  (Read 2190 times)
Offline UP
Throttle Pull
« on: June 29, 2012, 01:42:15 PM »
The throttle pull on my new 2012 is considerably harder than my old 2009. Gets tiring on the long rife from holding it. Cramp buster helps. Any ideas on how to lighten the throttle pull?
Thanks in advance.
UP
Offline jayke
Re: Throttle Pull
« Reply #1 on: June 29, 2012, 02:29:27 PM »
Is the grip draging on anything?   Either on the Bar end weight or switch cluster?
They shouldn't be that much different other than the new ones have heated grips.
Re: Throttle Pull
« Reply #2 on: June 29, 2012, 03:24:30 PM »
Maybe you're getting old!  :o
 8)
Offline UP
Re: Throttle Pull
« Reply #3 on: June 30, 2012, 03:38:48 AM »
Older yes. I'll look for friction points as you suggest and report back.
UP
Offline Wilsonos2
Re: Throttle Pull
« Reply #4 on: June 30, 2012, 05:05:00 AM »
If the throttle snaps back to closed after you apply full throttle I would say it only could be the spring that is stronger then the 09 spring. If it doesn't return quickly then you better get it looked at because it sounds like its dragging like others have said.
2009 Concours 14 Black. Area P slip-on, KN Filter, PC5, Flies Removed.
Offline UP
Re: Throttle Pull
« Reply #5 on: June 30, 2012, 09:29:34 AM »
The throttle snaps back just as it should and I can't see any friction points at the grip. I suspect a stiffer spring at the return setting but under too much plastic for me to diddle with. Next shop stop I'll mention it.
Thanks all,
UP
