Welcome,
Guest
. Please
login
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Calendar
Login
The C-14, aka Kawasaki Concours-14, the new one :)
The Bike - C14/GTR 1400
(Moderator:
chi-gpz1100
Throttle Pull
« previous
next »
Print
Go Down
Author
Topic: Throttle Pull (Read 2191 times)
UP
Newbie
Throttle Pull
on:
June 29, 2012, 01:42:15 PM »
The throttle pull on my new 2012 is considerably harder than my old 2009. Gets tiring on the long rife from holding it. Cramp buster helps. Any ideas on how to lighten the throttle pull?
Thanks in advance.
UP
Logged
jayke
Full Member
Re: Throttle Pull
Reply #1 on:
June 29, 2012, 02:29:27 PM »
Is the grip draging on anything? Either on the Bar end weight or switch cluster?
They shouldn't be that much different other than the new ones have heated grips.
Logged
jimmymac
Arena
Full Member
Country:
Re: Throttle Pull
Reply #2 on:
June 29, 2012, 03:24:30 PM »
Maybe you're getting old!
Logged
UP
Newbie
Re: Throttle Pull
Reply #3 on:
June 30, 2012, 03:38:48 AM »
Older yes. I'll look for friction points as you suggest and report back.
UP
Logged
Wilsonos2
Newbie
Country:
Re: Throttle Pull
Reply #4 on:
June 30, 2012, 05:05:00 AM »
If the throttle snaps back to closed after you apply full throttle I would say it only could be the spring that is stronger then the 09 spring. If it doesn't return quickly then you better get it looked at because it sounds like its dragging like others have said.
Logged
2009 Concours 14 Black. Area P slip-on, KN Filter, PC5, Flies Removed.
UP
Newbie
Re: Throttle Pull
Reply #5 on:
June 30, 2012, 09:29:34 AM »
The throttle snaps back just as it should and I can't see any friction points at the grip. I suspect a stiffer spring at the return setting but under too much plastic for me to diddle with. Next shop stop I'll mention it.
Thanks all,
UP
Logged
Print
Go Up
« previous
next »
(Moderator:
chi-gpz1100
Throttle Pull
