Author Topic: Converting C14 stock power outlet to Powerlet?  (Read 4896 times)
Offline jaclaw
« on: June 18, 2012, 05:46:22 PM »
Has anyone converted the stock C14 power outlet to a Powerlet?  I installed a 2nd stock outlet hoping to cure the problem of a loose connection.  No success.  Tired of stuffing toothpicks and still losing power to my GPS.  Just want to know if it is a direct replacement or if modification required.  Thanks,  Jim
Offline lt1
  • 2008 C14
Re: Converting C14 stock power outlet to Powerlet?
« Reply #1 on: June 19, 2012, 10:12:07 AM »
I used one of these Powerlet adapters:
http://www.powerlet.com/product/cigarette-insert-to-powerlet-socket-metal-adapter-neopreen-cap/1
I had to solder a small nut on the end to make a reliable connection.  I was going to post a pic, but seem to have misplaced the adapter.
Eyes, Brain, Hands.  Repeat.
Offline bigdaddyjob
« Reply #2 on: June 19, 2012, 11:25:02 AM »
I have seen these in my Ebay paroosing, but I dont know how well they work, they have both an all-time fused, and an ignition activated setup. Might be worth a try, then you could report back to us ;D
http://www.ebay.com/itm/Kawasaki-Concours-14-Dashboard-Power-Outlet-ALWAYS-ON-/160788347866?pt=Motorcycles_Parts_Accessories&hash=item256fbb7bda&vxp=mtr
Offline jaclaw
« Reply #3 on: June 19, 2012, 11:52:52 AM »
I already pulled the trigger on the Powerlet socket before the posting on the one from ebay, looks like I'll report back on that instead.  Thanks for both suggestions.  Jim
« Reply #4 on: June 19, 2012, 12:21:29 PM »
OUCH, 70 bucks.  Seems it would be cheaper direct from Powerlet.
http://www.powerlet.com/product/low-profile-powerlet-socket-kit-36/166
« Last Edit: June 19, 2012, 02:11:40 PM by 556ALPHA »
« Reply #5 on: June 19, 2012, 03:53:46 PM »
Yeah, but he is proud of his instructions......
 :D
Offline jaclaw
« Reply #6 on: June 24, 2012, 06:49:49 AM »
The PowerLet sockets fit fine in the space behind the left hand panel.  They are a little smaller in diameter and length and the installation would have been easier if I had not already installed a stock outlet.  Because the hole cut for the stock outlet was larger than the PowerLet  I had to use a fender washer  on either side of the plastic panel, but it turned out fine.
« Last Edit: June 24, 2012, 03:10:44 PM by jaclaw »
Offline McJunkie
« Reply #7 on: June 24, 2012, 10:48:40 AM »
I installed one on the left side as well. Ordered mine directly from Powerlet. Don't remember the price but it was way less than $70.
« Reply #8 on: June 25, 2012, 06:36:13 AM »
I may buy one after my upcoming maine/ canada ride.
Wow powerlet is proud of these, on their web page they show  butchered ZX14 subframe plastics  :o
« Reply #9 on: June 25, 2012, 02:27:46 PM »
I added mine to the left side. I wanted something I could keep the battery charged with and plug in my heated gear in the spring, fall and summer ridding months. :)
