Author Topic: Heli Horizon ST bars installed  (Read 3921 times)
Offline kawacop1642
« on: May 27, 2012, 03:37:21 PM »
WOW!!! what a difference these bars make. Not only in comfort, but the bike seems to handle better due to the bars being slightly wider in stance. The install took about 2 hours and was very easy. Hardest part was removing the left grip. A little alcohol made that job alot easier. After a few adjustments and getting the bars to fit me I took a quick 70 mile ride for the final analysis. Arms are now slightly bent at the elbows, seating position is much more relaxed, no hand numbness, no back or neck pain, and slow tight turns were effortless.
  Overall, IMHO, these bars are worth thier weight in gold. I'll be selling the risers and wedges.
Offline kawacop1642
Re: Heli Horizon ST bars installed
« Reply #1 on: May 27, 2012, 03:40:23 PM »
Also, they do not get in the way of my tank bag. However, it is a small low profile bag.
Offline TJ
« Reply #2 on: May 27, 2012, 04:08:43 PM »
Appreciate the information and the photos. What would you consider the most difficult part of the install?
2012 Black Kawasaki Concours
« Reply #3 on: May 27, 2012, 07:04:38 PM »
Hey- you shouldn't drink while performing bike maintenance :)
Looks great- I am jealous.
Offline kawacop1642
« Reply #4 on: May 27, 2012, 09:17:56 PM »
Seriously, the removal of the left grip was the hardest part. The rest was a breeze thanks to the well written instructions.
Offline kawacop1642
« Reply #5 on: May 27, 2012, 09:22:14 PM »
Funny.......Wrong alcohol bro. I meant rubbing alcohol. Of course I'm sure you new that. No need to be jealous Max. Run out and get yourself a pair of ST bars. I should have done this install from day one.
Offline Cuda
« Reply #6 on: May 27, 2012, 09:35:38 PM »
When I changed to LSL's I used a heat gun , you need to wear a glove when you twist it off ;) ouch.
Gods waiting room Naples
2011 Atomic  Silver
« Reply #7 on: May 27, 2012, 09:42:50 PM »
I am undecided still.  I have had good results with the Helibar non-Horizons, coupled with the wedges.  Plus, I do like the integrated RAM ball and powerlet (neither of which the Horizons have, which is pretty shocking considering the price).  Plus I am horrified about the idea of my trying to remove the powered grips without damaging them (just Grip Puppies alone gave me fits).  Also would be concerned if the Horizons would offer the same magic angle of the wedges that cured most of my pain/nerve problems.
Offline h2oplayer
« Reply #8 on: May 28, 2012, 09:47:08 PM »
Did you swap out the brake and or clutch cables?
Offline kawacop1642
« Reply #9 on: May 29, 2012, 06:48:50 AM »
I used the cable extension lines that came with the kit. Heli does offer a single line for brake and clutch (not an extension) but it's an additional $50.
« Reply #10 on: May 29, 2012, 07:44:26 AM »
I didn't get a chance this past weekend to get mine installed.  Did go on a ride with the wifey into Orange and Madsion counties (Virginia).  Didn't have any problems with my neck.  I was quite surprised at that.  It seems that having a passenger changed the ergos to the point where I was sitting straighter on the bike.  So I could have saved the money on the bars and just have my wife ride with me all the time.
« Reply #11 on: May 29, 2012, 07:47:11 AM »
She may appreciate such too
