Author Topic: Risers - why do so many different heights fit?  (Read 4155 times)
Offline TJ
« on: May 21, 2012, 08:54:23 PM »
I have added handlebar risers to maybe a half dozen bikes in my life. Some were easy, some were a nightmare. Seems that once you approach 2 inches you entered a new world with longer cables, brake lines, etc.
Why is it relatively easy to add 4 inch risers or less on the newer 2011/2012 ABS models? Did Kasasaki design these bikes with longer cables and lines knowing risers would be installed?
2012 Black Kawasaki Concours
Offline Gsun
Re: Risers - why do so many different heights fit?
« Reply #1 on: May 21, 2012, 09:27:02 PM »
I think it's more of that fact that you can reroute the lines. You have to undo the small block the holds the lines to the bars and let it flop as well as take them out of their hold downs. It's not quite a snap.
« Reply #2 on: May 21, 2012, 09:44:49 PM »
TJ- it is not necessary to keep creating new threads.  Post on an existing thread.... you already made one on risers (even though there are lot of those too)  here:  http://www.zggtr.org/index.php?topic=8851
Offline blanton
  • Rural East TEXAS
« Reply #3 on: May 21, 2012, 11:09:18 PM »
Tj besides risers you can instal setbacks too without changing cables...
77 KZ900 (still riding) 05 C10, 2010 C14
« Reply #4 on: May 22, 2012, 05:36:25 AM »
Those are interesting.  I want the bars back, but don't want them higher.  I guess that is impossible and this is the next best solution.  Are those the sport risers or something like that?
Offline blanton
  • Rural East TEXAS
« Reply #5 on: May 22, 2012, 07:34:38 AM »
Twowheeladdict, the setbacks are homemade from 1/2 in 6061 . Bought from Graingers and cut with hacksaw...
« Reply #6 on: May 22, 2012, 11:57:38 AM »
Trying to figure out the first photo showing one setback.  Are you using them with risers?  Do you think they could be used without risers?  If they can be used without risers then that is what I need to do.
Offline blanton
  • Rural East TEXAS
« Reply #7 on: May 22, 2012, 12:22:28 PM »
Yes they can be used without risers....
« Reply #8 on: May 22, 2012, 02:50:45 PM »
Can you provide details?  I would love to attempt this mod.  You do have some skills.  I saw a thread on your unique tail bag.
Offline blanton
  • Rural East TEXAS
« Reply #9 on: May 22, 2012, 05:05:43 PM »
No skills here...just wanted the bars back more...had saw a simular piece mounted on top of risers and thought about it on the bottom....cut a paper pattern using the up-right as a guide.. the drill bit and tap costs more than the material..I would suggest buying the 1/2 x 4 x 12in piece. In that order I also got material for these (pic)
« Reply #10 on: May 23, 2012, 06:04:01 AM »
Thanks Blanton.
