Author Topic: My Givi E55 is mounted, with pics  (Read 18917 times)
« on: April 08, 2012, 12:30:44 PM »
It took me a while, but I finally got my Givi E55 painted and mounted to a Phill rack. The color isn't perfect but pretty close...
I also mounted a Powerlet plug to the fairing while I was at it.
Offline jqram35
  • 2012 C-14 Candy Arabian Red
Re: My Givi E55 is mounted, with pics
« Reply #1 on: April 08, 2012, 12:58:37 PM »
Very very nice!
Jeff
« Reply #2 on: April 08, 2012, 02:35:10 PM »
 :thumbs: :thumbs:
Offline jimbob
« Reply #3 on: April 08, 2012, 03:25:31 PM »
Nice!
Jim
Offline philipintexas
    • Phils Farkels
« Reply #4 on: April 08, 2012, 04:08:39 PM »
Looks like a pretty neat wiring hook-up. how'd you do it, lots of people ask about this and yours looks like a really sanitary plug-in.
« Reply #5 on: April 08, 2012, 05:55:20 PM »
I'm using the stock plug that came with the Admore lighting kit. I drilled a hole and mounted the plug towards the bottom of the box, dead center. The power wire is routed through the same hole that the brake light assembly uses. I used a Dremel bit to carve out a small notch in the brake light assembly so I could easily feed the excess into the bike when I wasn't using the trunk. I also put a small bit of clear tape near the plug to protect the paint from getting scuffed by the plug.
Here's a picture with the trunk removed and the wire retracted.
Offline rush2112
« Reply #6 on: April 09, 2012, 11:36:38 AM »
Looks good!
I was wondering how one would look on this bike since I have the exact same one (color).
 :chugbeer:
"A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed
Offline Makz58
« Reply #7 on: April 10, 2012, 07:10:32 AM »
That looks very nice....question for you does your light kit include for turn signals if so where did you find access to the wires in the rear compartment.
C-14 2010
« Reply #8 on: April 10, 2012, 08:37:53 AM »
Yes, the Admore E55 kit includes turn signals.
If you remove the toolbox and slide out the ECU, you will find a large rubber boot towards the back that houses ALL of the connections from the taillight assembly.
There are some pictures floating around, but it's very self explanatory once you find the boot. By tracing the wires, you will notice that one plug goes to the brake, one plug goes to the license plate and 2 plugs go to the turn signals (one on each side). The ground is generally black and the power is generally colored.
Offline Makz58
« Reply #9 on: April 10, 2012, 09:22:19 AM »
Thank you will save me some time installing my own appreciate it..
C-14 2010
« Reply #10 on: April 10, 2012, 01:10:30 PM »
Does it bounce like crazy as you ride when its empty?
Mine shakes like crazy and I did install the foam strips Phil included.
« Reply #11 on: April 10, 2012, 02:07:51 PM »
I haven't notice any bouncing yet. My Phill rack came with really thick felt pad strips, not foam.
I did notice a bit of vibration and noise from the truck release button, but I resolved that with a couple strategically placed strips of Velcro (the soft fuzzy part).
« Reply #12 on: April 10, 2012, 02:10:57 PM »
Yes correct, that's what I meant.
« Reply #13 on: April 10, 2012, 03:41:53 PM »
MrPepsi,
I have had two different sets of Phils Racks/ E55 Trunks, don't ask.  The first set did have some bounce in it even after using the two strips.  On this current setup I installed 3 strips evenly spaced and have ZERO bouncing.  In fact it was kinda hard to get it secured to the rack the first time.  Hope that helps.
« Reply #14 on: April 10, 2012, 03:47:22 PM »
It sure does, I'll check into adding some strips. Thanks.
Offline Makz58
« Reply #15 on: April 10, 2012, 04:38:03 PM »
Mine I almost have to sit on it to lock it down very solid zero movement....only two felt strips...?
C-14 2010
« Reply #16 on: April 10, 2012, 06:05:15 PM »
Mine is also very difficult to lock down, I think it might be shaking on the back two posts.
Offline Makz58
« Reply #17 on: April 10, 2012, 06:33:10 PM »
Mine is not shaking very solid once I get it locked down...
C-14 2010
Offline cablebandit
« Reply #18 on: April 11, 2012, 08:01:44 AM »
Mine's rock solid but it's mounted to a Premier rack.
MGvalerio
« Reply #19 on: April 11, 2012, 04:32:15 PM »
 x top casa Kawasaki 47 litri.
MGvalerio. 8)
