Author Topic: C14 air cleaner  (Read 9049 times)
Offline paulthibodeaux
C14 air cleaner
« on: April 04, 2012, 04:09:49 PM »
Saw a post sometime back about changing the air cleaner without removing fairing.
Any body know where I can find the article?
Re: C14 air cleaner
« Reply #1 on: April 04, 2012, 04:20:07 PM »
It's not possible without removing the left side upper fairing.  Either that or you are a magician.
Offline pasini510
Re: C14 air cleaner
« Reply #2 on: April 04, 2012, 04:20:46 PM »
cant do it. Not as hard as you think
Andre
Re: C14 air cleaner
« Reply #3 on: April 05, 2012, 01:48:41 PM »
Got the air cleaner changed. Only had 18000 miles on it. Amazing the difference a clean filter makes.
You can changa the filter by removing the top cover or glove box and the piece that has the glove box on the 2010. Not easy but can be done.  I did take out the top screws on the left fairing.
Offline banditrider
  • Country: nz
  • Two wheels are all you need!
    • Off for a ride
Re: C14 air cleaner
« Reply #4 on: April 05, 2012, 02:36:49 PM »
It was an easier job than I thought (I'm no mechanic).  Mine ended up like this to get at it:
'08 Concours 14: Rad guard, Stebel, Oxford Hot grips, Projekt D Screen, Hugger, GPS mount, helmet locks & fender extender, Zumo 550, Stebel, Phil's rack & Givi V46, Sheepskin seat cover, Phillips Extreme vision +100 bulbs.
Re: C14 air cleaner
« Reply #5 on: April 05, 2012, 04:28:50 PM »
There should be an access panel to get to the air cleaner. Should not be this difficult.
Offline mike-s4
Re: C14 air cleaner
« Reply #6 on: April 05, 2012, 04:44:47 PM »
 An access panel would be great.  It looks worse than it  is.  After you've done it once , it only takes 10 to 15 minutes to change.
Re: C14 air cleaner
« Reply #7 on: April 06, 2012, 06:44:41 AM »
If you're going to remove the plastic, it's good to have more than one thing to do to the bike while you're at it. Last fall when I replaced my air cleaner, I also did a coolant flush & fill and then checked the exhaust header nuts. I changed the oils too but you don't need the plastic off for that.  When you've had the plastic off once, it's a piece of cake the next time around.
Just remember where all the fasteners go.    :o
Offline feelergaugephil
Re: C14 air cleaner
« Reply #8 on: April 06, 2012, 10:42:57 PM »
It took me 20 mins today, I put a new K/N in it, simple job....
Dont take my LOW post count as being a new Connie owner, I have been with the "other site" before it imploded........
13 Connie dressed in blue
Offline Ddfee
  • Be the person your dog thinks you are
Re: C14 air cleaner
« Reply #9 on: April 06, 2012, 11:57:27 PM »
You want stupid air cleaner changes try the gl1800 goldwing, total biotch to change, dismantle half the bike to get at it.  First time changing it was a weekend job. You remove the dash, Tupperware, then dig it out from under two huge wiring harnesses.  I'm sure the c14 is gonna be easier.
D
2011 C14
2003 Honda GL 1800
2000 Honda Blackbird
IBA Member
Re: C14 air cleaner
« Reply #10 on: April 07, 2012, 02:22:26 PM »
I will do mine one day when I am good and drunk. :chugbeer:
Re: C14 air cleaner
« Reply #11 on: April 07, 2012, 04:51:31 PM »
I'll help! ;D
Re: C14 air cleaner
« Reply #12 on: April 07, 2012, 06:07:33 PM »
I'll help! ;D
I seriously doubt we would get much working done......so when you heading this way anyways?
Re: C14 air cleaner
« Reply #13 on: April 07, 2012, 07:38:59 PM »
 :offtopic: Well, I did 300 miles today in 150 mile stints, then pulled weeds with my right arm and so far no issues.  I could feel some tenderness in my neck but no problems with the shoulder or the arm.  My next feat tonight will be two martinis.  I will use my right arm and see what happens....
With that being said it will be this summer, don't know yet.  I'll head out your way and stay near you and then on to Illinois to bother Conrad and anyone else that gets in the way.
The Area P is sounding very nice.  I'm getting used to the sound and I must say I like it.  No decel pop at all.  Disappointed over that.
Re: C14 air cleaner
« Reply #14 on: April 07, 2012, 07:52:54 PM »
No......you will be staying at my nest Robin!!!! >:(
Re: C14 air cleaner
« Reply #15 on: April 07, 2012, 09:03:09 PM »
Most excellent, of course!
Re: C14 air cleaner
« Reply #16 on: April 08, 2012, 05:01:34 AM »
Silver Convention - Fly, Robin, Fly - 1975
I'm glad to hear that the neck is feelign better Jim.
Re: C14 air cleaner
« Reply #17 on: April 08, 2012, 07:45:48 AM »
I had to listen to all of that....I like disco.  Course it's hard to dance like that in armour....not that I can dance, I can't.  Well, I could if someone was shooting at my feet. Wouldn't be as good as them, though.
Re: C14 air cleaner
« Reply #18 on: April 08, 2012, 09:25:02 AM »
Take the long route Sparky and swing by Oregon on the way to C's...  ;)
Re: C14 air cleaner
« Reply #19 on: April 09, 2012, 05:11:45 AM »
Just a small detour right J?    :thumbs:
