Author Topic: Little black rivit thing part number???  (Read 4828 times)
Offline jamcou2020
« on: March 09, 2012, 11:41:00 AM »
Can anyone give me that part number to those little black plugs that secure the fairing that you have to push in the middle to take out. I didnt know that and broke a few I would like to have them replaced.
Re: Little black rivit thing part number???
« Reply #1 on: March 09, 2012, 11:43:15 AM »
You might look in the C14 Wiki area under part numbers.  You'd be amazed at what you would find....
http://www.zggtr.org/index.php?topic=1650.0
Offline jqram35
  • 2012 C-14 Candy Arabian Red
« Reply #2 on: March 09, 2012, 12:01:37 PM »
Went by the dealer yesterday and they gave me some different ones that have a philips head on them. A little wider and look much stronger. I did not get a part number. They did not have any of the regular ones in stock.
Jeff
Offline jqram35
« Reply #3 on: March 09, 2012, 12:18:21 PM »
They measure .225 in diameter making them 5.7mm. Thinking that would make them the 6 mm version seen on line and on ebay.
Jeff
Offline C14PAINKILLER
2010 PAINKILLER BLUE   COG# 9405
Rides the metal monster, breathing smoke and fire
« Reply #5 on: March 09, 2012, 01:20:37 PM »
Try Murph's, he has them!
http://www.murphskits.com/catalog/product_info.php?cPath=130_136&products_id=281
Cheers
Wrong part. These are the nuts. The OP is looking for the rivits. But good to know anyway.
From Wiki
"Nylon Push Rivet (two sizes) - 92039-0051 & 99039-0051
Push rivet under the windscreen - 92039-0048
Motosport.com Bolt Brand 6mm Nylon Push Rivet - 2005-6RIV (These may not work)
Balkamp part number 665-1446 (pkg of 9) available at NAPA for (rivet 92039-0051)
Hillman push-in Nylon Rivet - 1/4 inch H#881216 (Lowes) barcode 0823671607, for the top of dash"
Offline jamcou2020
« Reply #6 on: March 09, 2012, 01:23:42 PM »
Thanks guys for all your help!!! What does OP mean???
« Reply #7 on: March 09, 2012, 01:25:45 PM »
OP = Original Poster. You in this case.  ;D
« Reply #8 on: March 09, 2012, 02:32:11 PM »
How about these ribbits...  They're not black, though.
Frog Ribbit Up-Close Discovery Channel Type Stuff - Watch!!!
« Reply #9 on: March 09, 2012, 04:01:23 PM »
« Reply #10 on: March 09, 2012, 04:14:34 PM »
I know his cousin!
« Reply #11 on: March 09, 2012, 10:55:29 PM »
OOps, my bad. Just like Pope posted, I got the ones from Lowes for like $2 for 4. Then I later found out I also needed the nuts when I was removing the fairing lowers :banghead:
Offline OCK913
    • The Orlando Riders Club
« Reply #12 on: March 09, 2012, 11:56:50 PM »
The part # you might be looking for is 92039-0051 but the last time I went to buy one at my dealer, they wanted something like $3 for 1 and they sold a pack of 10 from an aftermarket brand that was only $6. so I went with them, same size and no noticible difference in holding ability. I dont remember the name of the other brand though ..... sorry
            2009 Kawasaki C14 - Black
« Reply #13 on: March 10, 2012, 05:49:41 AM »
Currently I'm using NAPA 665-1316 push rivets.  They have a taller center push knob to tighten them up and it doesn't go all the way in.  So far they hold tight and you haven't something to grab to pull them out.  Might be a bit ticklish to remove if the screen is all the way down but so far I like them.
