Author Topic: New Rotors from China  (Read 30024 times)
Offline buzzcut
« on: May 19, 2011, 09:15:43 AM »
http://cgi.ebay.ca/Full-Set-Brake-Disc-Rotor-Kawasaki-ZG1000-86-93-/310255921453?pt=Motorcycles_Parts_Accessories&hash=item483cb1a92d
Hopefully this link will work.  I bought these and wow, do they ever improve on the old ones on my 86.  All are 5mm.  I didn't put it on the rear but the three together were cheaper than just the front two.
The countersink for the screws to mount it was not quite wide enough for the heads to fit inside but there was enough head size to secure easily and not be a safety concern.  Really grippy once they are seated with the pads.  so much so, I made a mistake on a parkade down ramp to avoid a car.  Laid the bike bike down finally.  On the plus side, I have the highway pegs from  Murph and I always wondered if they would work like a tipover bar.  Glad to say  they do.  No damage to anything.  I think that if there was a fashion statement for rotors, these are it:)
« Last Edit: May 19, 2011, 01:53:08 PM by buzzcut »
Offline mlf73
Re: New Rotors from China
« Reply #1 on: May 19, 2011, 11:25:36 AM »
Your link doesn't seem to work...shows that the item is no longer available.  I got my replacement rotors from China also.  I went with the 310mm petal rotors since I had upgraded to 4 pot calipers and had room for the larger rotors.  I've had no problems with them so far after about a year and a half.
Offline buzzcut
« Reply #2 on: May 19, 2011, 01:53:41 PM »
tired a different link  hopefully this will work
Offline snarf
« Reply #3 on: May 19, 2011, 03:08:21 PM »
Damn those are sharp.  I think a set of those might just have to go on the Spirit.
Can you post some pics of them mounted?
2002 Conc
1986 Conc "The spirit of COG"
Offline deadzed
« Reply #4 on: May 19, 2011, 07:33:19 PM »
Looks great. Too bad the ones that fit my '05 are still stupidly expensive.
“And I to my motorcycle. Parked like the soul of the junkyard restored, a bicycle fleshed with power, and tore off up Highway 106, continually drunk on the wind in my mouth. Wringing the handlebar for speed. Wild to be wreckage forever”
James Dickey
Offline buzzcut
« Reply #5 on: May 20, 2011, 09:05:42 AM »
I shall try to add pics this weekend
Offline blade
« Reply #6 on: May 20, 2011, 10:12:41 PM »
Same vendor on ebay just has them listed as GTR no ZG1000.
http://cgi.ebay.ca/Front-Brake-Disc-Rotor-Kawasaki-GTR-1000-94-06-/140460125648?pt=Motorcycles_Parts_Accessories&hash=item20b4136dd0
I think the rear on the 05 is still that same as it was on 86-93
« Reply #7 on: May 21, 2011, 05:37:18 AM »
The rear never changed 86 through 06 all the same.
Offline deadzed
« Reply #8 on: May 22, 2011, 09:15:05 PM »
Very helpful. Thanks!
James Dickey
Offline roadkoan
  • Some are as the river, some are as the rocks.
« Reply #9 on: May 24, 2011, 05:43:21 AM »
I just ordered a pair. (of rotors thank you)
Report to follow...
'02 C-10
Offline buzzcut
« Reply #10 on: May 24, 2011, 10:55:23 PM »
so here is a pic.  Not fully seated in yet
Offline Uglydog56
« Reply #11 on: May 25, 2011, 08:59:20 AM »
What's the deal with stainless vs. steel for rotors?  EBC says 20% more stopping power over stainless, but galfers are stainless and they obviously don't suck.  Is that marketing hoopla or is there some truth to it?  I wouldn't want to lose the 20% increase in braking I just added with 320mm rotors and 4 piston calipers by using the wrong stuff.
Rick A. Cone
COG #9186
98 Connie, 76 CB400F
« Reply #12 on: May 25, 2011, 09:10:08 AM »
Carbon Steel can have a courser more open grain pattern which will improve friction but will rust.... Stainless Steel will not rust but has a slightly more slick closed grain pattern has slightly lower friction. To which EBC uses Stainless Steel rotors and Galfer is known for their "Iron" rotors that when new have such sharp edges that they can and will cut you; these edges are hard on a pad but they do add a lot to the friction and thus grab much tighter.
enim57
« Reply #13 on: May 26, 2011, 08:10:50 PM »
Having put steel rotors on mine I would advise against it as they will rust and and put a light film of rust over the wheel, forks, calipers, fairing, etc. I have not noticed much of an improvement (if any) over stainless steel discs. I am soon to buy a set of the Chinese rotors. Note I have 4 piston Nissin calipers.
Regards, Russell
Offline Daytona_Mike
« Reply #14 on: May 27, 2011, 01:37:46 PM »
Regards, Russell
Do you have 320mm rotors? If so please post the link to the ones you buy and let us know how it worked out. I maybe in for a set too,320s that is.
Offline buzzcut
« Reply #15 on: May 27, 2011, 02:16:24 PM »
I am not sure what the original rotors were made of, but these stainless ones are way grippier( is that a word).  I am happy with them
Offline Strawboss
« Reply #16 on: May 28, 2011, 12:11:56 PM »
Did I read correctly that shipping, economy shipping is $60USD? $60? More than one third the total cost of the items? And made in China? Sorry, don't want to start an argument but I'll pass, even at that price.
Offline buzzcut
« Reply #17 on: May 28, 2011, 03:26:24 PM »
Ah well, considering EBC wants 375 per rotor plus shipping, and these are all three for 220, well that's different math in my books.  don't knock china, they are buying all our coal and metals and adding value to it.
« Reply #18 on: May 29, 2011, 03:42:43 PM »
use them hard on a rainy day, and put the bike in a garage for a week. Tell us if they rust.
Stainless ain't always stainless, there are many grades, some work great for rotors, some don't. Some rust, and some don't....
oh, if they warp, $220 was a costly gamble. Not to say EBC would give you new ones if they warp, but I'd think you would have a better chance of it.
Offline buzzcut
« Reply #19 on: May 30, 2011, 08:18:36 AM »
Well, my bike sits outside all the time, and gets wet with the sprinklers too, not to mention we have had our annual rainfall in the last two weeks and I can say no rust.  warp, well only time will tell.  I went through two sets of original rotors with warp so...  In all fairness though, even with maintenance every year on the calipers, I had the left one seize and hence the warp.
