Author Topic: Right side cover bolt now stripped  (Read 19245 times)
Re: Right side cover bolt now stripped
« Reply #40 on: January 26, 2012, 02:47:00 PM »
Whatcha gonna work on next?
« Reply #41 on: January 26, 2012, 03:05:38 PM »
Looks like 92153D and 92200
Thanks!
I see 92200 says washer. I don't have a washer on mine. Is it one of the white plastic washers or steel?
« Reply #42 on: January 26, 2012, 03:21:29 PM »
Very thin white washer.
« Reply #43 on: January 26, 2012, 03:27:39 PM »
He has that new battery coming from Murph's to install...      :o
Offline Shoe
« Reply #44 on: January 26, 2012, 03:35:22 PM »
I saw on another thread recently somebody said to strategically weld a nut to it, I don't have a welder in my garage but maybe you do?  :-\
Good luck MP, that sucks bro...  :(
I would not try to weld, its too close to the plastic.
Eat corn. Drill for oil.
2008 Concours, 2010 Goldwing
« Reply #45 on: January 26, 2012, 03:40:15 PM »
You guys are brutal.
At least I'm not a CDA member, oh crap.
« Reply #46 on: January 26, 2012, 03:42:52 PM »
Sorry Brent, you know it's all in good fun. We've all been there, well, maybe not exactly THERE but you know what I mean.    :)
« Reply #47 on: January 26, 2012, 03:52:24 PM »
No worries, I can do some stuff, just don't have enough patients to do it flawlessly sometimes.
« Reply #48 on: January 26, 2012, 03:54:33 PM »
hehehe, he gets to take the cover off again.
« Reply #49 on: January 26, 2012, 04:15:44 PM »
I think that was 'Danger Will Robinson, Danger.'
The guy who did the voice for the robot just died. I don't know if the guy who flailed the hooks around is alive or not....
Oh man... :'(
« Reply #50 on: January 26, 2012, 04:15:44 PM »
Silly guy, the bolt is broken, I can't even get the cover on!
« Reply #51 on: January 26, 2012, 04:19:24 PM »
 :chugbeer:
« Reply #52 on: January 26, 2012, 04:21:10 PM »
 :deadhorse: :rotflmao:
Flathead
« Reply #53 on: January 26, 2012, 06:17:23 PM »
Here ya go Brent
« Reply #54 on: January 26, 2012, 06:36:32 PM »
Yeah but I think the stud is stuck in the battery box cover, not the frame itself. It is still a steel stud stuck in an aluminum plate but at least the plate is removable and so can be repaired more easily and with less risk (not hacking into the frame itself). Worst case scenario is he would have to buy a new battery box cover, and they might even be available used these days.
He didn't get the bolt out, he twisted the head of it off.  Bolt is still in the frame......
« Reply #55 on: January 26, 2012, 06:37:10 PM »
True but remember- nothing screams bad craftsmanship like wrinkles in your duct tape....
Here ya go Brent
Offline koval68
« Reply #56 on: January 26, 2012, 08:03:49 PM »
Are you related to Steve Smith (The Red Green Show), Brian?
- Mahatma Gandhi
Offline ZedHed
« Reply #57 on: January 27, 2012, 02:04:45 PM »
I went thru the same issue when I was pulling the battery for winter storage. Three out of the 4 bolts I had to remove stripped out. I initially tried a bolt extractor with no luck. Then I tried drilling into the bolt with a bit that was smaller than the shank of the bolt and carfully drilled in most of the length of the bolt. I tried the bolt extractor repeatedly during this process until the bolt lost enough of it's holding power to come out. I ordered replacement bolts which are not yet installed and I would really like to know that when I put them in I wouldn't have the same problem again.
I put anti-seize on those bolts so they don't get stripped out the next time I remove them
« Reply #58 on: January 27, 2012, 02:15:03 PM »
I bugger up one bolt and you guys tease to no end.
This guy buggers FOUR bolts and he gets advice. ;D
« Reply #59 on: January 27, 2012, 02:24:44 PM »
« Last Edit: January 27, 2012, 06:28:27 PM by ZG »
