Author Topic: Right side cover bolt now stripped  (Read 19244 times)
Re: Right side cover bolt now stripped
« Reply #60 on: January 27, 2012, 02:29:33 PM »
I bugger up one bolt and you guys tease to no end.
This guy buggers FOUR bolts and he gets advice. ;D
You want some advice Brent?
Ok, don't do that again and put some Captain Morgan in with that Pepsi.    :chugbeer:
« Reply #61 on: January 27, 2012, 02:41:56 PM »
That, quite possibly could be what caused the bolt issue. ;)
« Reply #62 on: January 27, 2012, 04:25:35 PM »
Does seem strange doesn't it?
« Reply #63 on: January 27, 2012, 10:31:18 PM »
He has a cute Polar Bear and appears to be in AK.  You have a bike named Razzi and live in CA,, what were ya expecting, a snuggy? ;)
« Reply #64 on: January 28, 2012, 02:29:18 AM »
Offline Tim
« Reply #65 on: January 28, 2012, 04:33:08 PM »
You guys are brutal.
At least I'm not a CDA member, oh crap.
Mr. pepsi, I hope you didn't Jinx yourself..........
« Reply #66 on: January 28, 2012, 08:17:08 PM »
Never had an issue getting out any of my bolts, and a good quality bit makes all the difference. Put some anti-seize on the bolts after removal, shouldn't have any more issues........and don't over-tighten. ::)
« Reply #67 on: February 11, 2012, 10:28:29 PM »
You guys just might be proud of me. I ordered new bolts and washers for my stripped bolt. Then I went to work. Drilling, drilling, drilling, finally broke through the back side. After busting drill bit after drill bit. No worries, there's nothing behind this bolt. Finally got my remover locked in good, and used vice grips.
Then went to home depot and matched up the threads, 6mm by the way with a nice 3" bolt with the same pitch. Ran it through a few times to get the threads good. Then bought some anti seize and set my bolt right. Got the cover back on. Granted when I was pissed about it stripping earlier in this thread I had some issues with the drill falling off and causing some scratches that I will fix up when I find my touch up paint, but the cover is back on.
yay.
« Reply #68 on: February 12, 2012, 12:27:13 AM »
Nicely done Brent!!  5 pages, 1 stripped bolt, I'd say you was approaching Haraldo territory ;)
Offline CrashKLRtoConnie
« Reply #69 on: February 26, 2012, 06:36:52 PM »
Brent
Congratz. I still feel the OEM bolts / screws are low quality given the results I have found with allen head sockets and use of a torque wrench.
Back from Florida and in the bay area for a few weeks and did a short ride on my 2008.
Only had to add 6 psi in the tires and use the battery tender and she fired up .... and rode great after 6+ months garage storage. (sad I am leaving again in a few weeks)
Best Off All
Brent
2008 C14 GTR1400 AKA "Connie"
