Author Topic: Ehaust Remove and Replace Question.  (Read 7423 times)
Offline marku8a
« on: January 21, 2012, 09:49:24 PM »
I am considering going with the Area P full exhaust system. Looking at the maintenance manual, it says that the radiator needs to be removed. I don't really want to break into the coolant system. Is it possible to remove and replace the exhaust without removing the radiator?
Mark
2009 C14 Red
Re: Ehaust Remove and Replace Question.
« Reply #1 on: January 21, 2012, 10:48:21 PM »
Yes.  I left the uppers connected, bottom swings enough to get things done.  It really is a quick job.  I may remove mine just to touch up the High temp header paint I did some 30000 miles ago.
Offline SpazOnaConcours
« Reply #2 on: January 21, 2012, 11:27:22 PM »
You want to take the lower radiator mount off and pull the radiator a bit forward at times, but it can be done without radiator removal. I hope you have good, thin tools for the nuts though... 1/4 drive stuff (extensions and/or wobbles), and/or good flex-head ratcheting box ends are nice too. :)
Offline timbo
« Reply #3 on: January 22, 2012, 07:04:13 AM »
+2
I took the upper and lower radiator bolts out and used a bungee coed around the front forks to hold the radiator forward, out of the way.
« Reply #4 on: January 22, 2012, 07:59:22 AM »
Replace the header nuts with Fuji-locks while you're at it.
Offline So Cal Joe
« Reply #5 on: January 22, 2012, 09:25:24 AM »
I don't want to hijack your thread but I'm going to have the 15000 miles service done soon and I would like to know what size Fuji nuts for the header bolts so I can have them replaced at that time.
« Reply #6 on: January 22, 2012, 09:37:08 AM »
Joe, I don't remember if they are 6 or 8mm. If nobody chimes in I'll check later.
http://www.boltmotorcyclehardware.com/advanced_search_result.php?search_in_description=1&keywords=fuji+lock&x=9&y=6
Just checked-8x1.25mm
« Last Edit: January 22, 2012, 10:50:23 AM by gPink »
Offline philipintexas
    • Phils Farkels
« Reply #7 on: January 22, 2012, 12:03:37 PM »
If you don't remove the radiator, be very careful in working around it. I think it is made of aluminum foil and can be damaged just by looking at it wrong.
Offline marku8a
« Reply #8 on: January 22, 2012, 12:12:13 PM »
Thanks for tips guys. I did learn about the Fuji-locks in another thread. I think I have almost every tool under the sun.  I do have a good selection of sockets, ratchet extensions, universal swivel, etc. I think I will order my system tomorrow.
Thanks again!
Mark
2009 C14 Red
Offline timbo
« Reply #9 on: January 22, 2012, 01:38:43 PM »
And don't forget to change the header gaskets, they are only a one time use.
Offline marku8a
« Reply #10 on: January 22, 2012, 03:41:38 PM »
Excellent point! Thanks for the reminder!!
Mark
2009 C14 Red
Offline So Cal Joe
« Reply #11 on: January 23, 2012, 08:18:45 AM »
Thank you, I'll get some and have the dealer put them on when I have my 15,000 mile service done.
Offline basmntdweller
    • The Profile Brotherhood
« Reply #12 on: January 23, 2012, 01:36:38 PM »
Just curious, what is so special about Fuji nuts and what is wrong with the factory nuts that are on there?
Are these the gaskets to the engine block? I just bought a set of ZX-14 pipes and muffler for my C-14, same header gasket?
Thanks, Matt
'09 C14
'98 DR-350
'03 Honda CBR600RR track bike
Offline Gearhead82
« Reply #13 on: January 23, 2012, 01:58:11 PM »
Thanks, Matt
Yes, the ZX-14 uses the same header gaskets as the C14 and those are the ones you'll want to replace when you put the new system on.
The Fuji lock nuts have some steel tabs in them that prevent the nuts from backing off, which the stock ones are known to do.
Offline wildnphx
« Reply #14 on: January 23, 2012, 06:36:32 PM »
Is it really worth the $54 dollars or would a little locktite on the threads be ok?
« Reply #15 on: January 23, 2012, 06:48:53 PM »
What 54 dollars?
Flathead
« Reply #16 on: January 23, 2012, 06:54:38 PM »
You only need 8 of them... Most places sell them in a pack of 10 for $9-$16...
Here is an example for $8.76 + $7.95 shipping:
 http://www.amazon.com/Motion-Pro-Nut-Fuji-Lock-Head138mm/dp/B00230OPWO/ref=sr_1_1?ie=UTF8&m=A1QMOGWERWEUPX&s=generic&qid=1327369959&sr=1-1
Offline wildnphx
« Reply #17 on: January 23, 2012, 07:30:49 PM »
My bad they come qty 10 to a pack...  I was wondering why the heck there were so expensive...  lol
Flathead
« Reply #18 on: January 23, 2012, 07:39:06 PM »
 I wouldn't buy them at $54 either LOL  :chugbeer:
Offline wildnphx
« Reply #19 on: January 23, 2012, 07:42:50 PM »
Order has been placed so the new muzzy will be put on right the first time...  Only thing left to get before the Muzzy arrives is the exhaust gaskets...
