Author Topic: Ehaust Remove and Replace Question.  (Read 7428 times)
Re: Ehaust Remove and Replace Question.
« Reply #20 on: January 23, 2012, 07:47:07 PM »
Are you going to run a PCv?
Offline Cheesecake
2008 C-14
Offline marku8a
« Reply #22 on: January 29, 2012, 07:19:11 PM »
gPink – I am not sure if your question is for me, the Original Poster. Yes I installed a PCv when I removed the flys. The most noticeable difference the PC made was the transition from throttle closed the just cracking it open. I made the other recommended fixes (adjust the cables, Throttle Tamer). Those changes made a big difference. With the PC the bike behaves like you would expect it to in the first place. I now can crack open the throttle while leaned over in a fast turn with confidence that I am not going to get a big unexpected whack of power.
2009 C14 Red
Offline wildnphx
« Reply #23 on: January 29, 2012, 10:25:44 PM »
If the question was for me then yes I alredy run a PCV and will be adding on autotune when Muzzy goes on this week...  I will be selling my two brothers slip on in case anyone is interested...  Love the sound of the Two Brothers...
