Author Topic: Shift to 1st gear, engine dies time and again...WTF??????  (Read 13743 times)
Offline ninjawarrior1400
« on: January 07, 2012, 06:22:44 PM »
Have a well maintained 2010 C-14 with 6000 miles on it.  Today .....started it up, shifted to 1st gear, engine immediately died......repeated proceedure from neutral...same results.  Would not let me start the bike from any gear with clutch pulled in!!
Never heard of this happening to anyone....WTF??? Anyone had this problem, and if so why, how to resolve?
Waited 5 minutes repeated proceedure...started up fine......rode for two hours....came home, stopped for 15 minutes...tried to restart...same thing happened...died when shifting to 1st gear.......never heard of this occurring to anyone else.....
Why, what is the cure??
Ninjawarrior
Ninjawarrior
Offline ljcorby
  • COG#: 9359
Re: Shift to 1st gear, engine dies time and again...WTF??????
« Reply #1 on: January 07, 2012, 06:25:04 PM »
Could it be a problem kick stand switch?
10 Kawi Concours 14 ABS
« Reply #2 on: January 07, 2012, 06:30:45 PM »
^^^^^^^THIS^^^^^^^^^
Excavator
« Reply #3 on: January 07, 2012, 06:33:32 PM »
That's what I would check first.
Offline Front Runner
« Reply #4 on: January 07, 2012, 06:34:18 PM »
Sounds like the kick stand switch also.
2008 Kawasaki Concours 14
« Reply #5 on: January 07, 2012, 06:55:35 PM »
+5  RT's had an issue with this.
Offline Scaffolder
« Reply #6 on: January 07, 2012, 07:14:57 PM »
My 2010 C-14 doesn't have an active kickstand switch. I figured it didn't have one. I know my 2008 had it.
Good luck with the first gear. What RPMs are you idling at when shifting in?
Joel from Maine.
« Reply #7 on: January 07, 2012, 07:17:10 PM »
So if you put the stand down in 1st gear the engine does not turn off?
Offline ljcorby
  • COG#: 9359
« Reply #8 on: January 07, 2012, 07:17:52 PM »
It absolutely should.
Offline So Cal Joe
« Reply #9 on: January 07, 2012, 07:19:52 PM »
Mine has a switch, all of them do, if yours runs when the stand is down there is something wrong with your kick stand switch
« Reply #10 on: January 07, 2012, 08:11:41 PM »
Check KiPass FOB battery too  ;)
Offline Ninjawarrior
« Reply #11 on: January 07, 2012, 10:14:40 PM »
My kickstand is up, started engine, clutch in, push down for 1st gear....engine immediately dies.  Not all the time.... Sporadic failure.
Diagnosis riders?
Ninja
Offline Gsun
« Reply #12 on: January 07, 2012, 10:36:07 PM »
Bad kickstand switch. No other reason. Well, maybe no other reason.....
« Reply #13 on: January 08, 2012, 07:32:03 AM »
Diagnosis riders?
Ninja
Get your multimeter out and check that switch.
Offline Z71
« Reply #14 on: January 08, 2012, 07:51:08 AM »
Also, the kickstand switch can be bypassed by using a jumper wire.  That way you know for a fact that this is the problem if the engine does not stall.
« Reply #15 on: January 08, 2012, 08:01:11 AM »
Yep, that would be the *best* way to test it, if it is intermittent.  Just remember that the jumper is overriding a relatively important safety feature.
Offline Scaffolder
« Reply #16 on: January 08, 2012, 11:07:54 AM »
I know for sure my switch doesn't work properly. I hate going to the dealerships. I am going to have to this Spring to get my tire sensors changed. The dealer I used last has no software to register my TPSs. They shouldn't have done the work if they didn't know how.
Joel from Maine.
« Reply #17 on: January 08, 2012, 11:53:52 AM »
WTF..........the OP has abandoned his own thread?
Offline Gsun
« Reply #18 on: January 08, 2012, 11:56:20 AM »
Maybe he's out testing his kickstand switch.
« Reply #19 on: January 08, 2012, 05:01:58 PM »
I hate when that happens...
