Very easy pad change. Took around twenty minutes, which included cutting and lighting the cigar that I was smoking while doing it. Don't forget to coat the retaining pin threads with anti-seize.Did you try to bleed the left side caliper?
Did you try to bleed the left side caliper?Didn't try that. I figure to wait until spring when I'll be changing out the brake/clutch fluids.
