Author Topic: Front brake pads gone at 13K miles.  (Read 5589 times)
Offline CigarSki®
  • Newb again?
Re: Front brake pads gone at 13K miles.
« Reply #20 on: December 10, 2011, 07:21:42 AM »
Very easy pad change. Took around twenty minutes, which included cutting and lighting the cigar that I was smoking while doing it. Don't forget to coat the retaining pin threads with anti-seize.
Wayne Sikorski aka CigarSki
2010 ZG1400 - South Jersey
COG 9250
« Reply #21 on: December 10, 2011, 07:24:52 AM »
Did you try to bleed the left side caliper?
Offline gildaguz
« Reply #22 on: December 17, 2011, 12:01:47 PM »
Just checked the stock ft brake pads on my 09  non abs with 16k and find out that  the inner pads on the right caliper and the outer pads on the left one are a lot more worn that the others
2009 Non ABS Concours Black
2004 Honda Shadow  Sabre 750
1979 Suzuki 185 all terrain
Offline CigarSki®
  • Newb again?
« Reply #23 on: December 17, 2011, 12:15:39 PM »
Didn't try that. I figure to wait until spring when I'll be changing out the brake/clutch fluids.
COG 9250
Offline feelergaugephil
« Reply #24 on: December 20, 2011, 11:28:57 PM »
26K on mine, changed to EBC HH, hated them, very very noisy, switched back to stock Kawasaki, happy again.
Dont take my LOW post count as being a new Connie owner, I have been with the "other site" before it imploded........
13 Connie dressed in blue
Offline Shadowofshoe
  • Mastiff pup/human pup
« Reply #25 on: December 22, 2011, 03:49:05 PM »
    Anyone have a ballpark cost on the OEM kawi's I like the way the stockers work-non-ABS.
          Thanks-
                       Mike
Sooooo....we are about to be a Nation that makes you prove you have insurance-but it's not necessary to prove that you are indeed a Citizen of that Nation?
« Reply #26 on: December 23, 2011, 08:17:05 PM »
Around $160 for front & back.
Offline sf bay rider
  • Humble student of the ZG1400
« Reply #27 on: December 27, 2011, 09:18:46 AM »
I replaced all the pads 13.8K barely half worn. Was tired of the loud squeaking sound. When brakes lightly applied. Despite repeated cleanng of calipers, pads and rotors. Left front pad showed a high degree of scoring on the pad surface. Cause unknown. All rotor surfaces smooth and free of abrasion. No warping noted either. Replaced OEM pads with EBC HH sintered pads. I'm happy with the results.
Jack
2014 Red ZG1400CEFL
Offline turbohawk
« Reply #28 on: January 07, 2012, 09:01:44 AM »
I got 20k out of mine but they wore very unevenly. Watching the replacements very closely.
