Author Topic: Difference between model years  (Read 13631 times)
Re: Difference between model years
« Reply #20 on: March 11, 2012, 07:32:28 AM »
And the 2008/2009 didn't have ram air?  What are the tubes running from under the headlights up to the air box?  They might have made a revision but I don't think it is much different.
Offline basmntdweller
    • The Profile Brotherhood
« Reply #21 on: March 11, 2012, 08:00:46 AM »
Also, I don't know if there is really a change in the top speed but I can tell you I tested my bike up to 153 mph in 5th gear and it wanted to continue...I didn't.
Not to be a smart ass or anything, but is there a much better chance of survival from a crash at 100 versus 170 on a bike? I wouldn't think there would be much difference in the fines either.
On the other hand, my balls do seem to shrink smaller and smaller the faster I go ;D
Matt
'09 C14
'98 DR-350
'11 Suzuki C50T wife's ride since she hates my Connie
'03 Honda CBR600RR track bike
« Reply #22 on: March 11, 2012, 09:32:08 AM »
There is probably a *huge* difference in survival rates between such speeds.  But one can die at 30MPH and survive at 100MPH, it all depends on exactly what happened.  But speed is always a really big factor.  As for tickets, I don't know.
« Reply #23 on: March 11, 2012, 09:33:36 AM »
Differences in the bikes, guys.  Differences only, please.
« Reply #24 on: March 11, 2012, 09:36:39 AM »
Hi guys,
Had lost track of the forum when, as someone said, it went poof!
Happy to be back!
Isn't the radiator also different since 2010 ? Isn't it now curved (bigger?) and also be part of the reason the newer 14 run cooler than the 2008 and 2009?
Nope, same part number.
« Reply #25 on: March 11, 2012, 09:37:41 AM »
Oh, so that's when them thar holes are for.....ramming speed.
« Reply #26 on: March 11, 2012, 10:36:15 AM »
I am not sure.  Maybe it was just revised.  I do know that just because an air intake is at the front, doesn't necessarily mean it is ram-air; that requires them to be exactly positioned for effective, high-pressure feeding.
It is even listed on Wikipedia:  "The fuel injected engine on the 2008 and 2009 models has a power output of 114 kW (153 hp) at 8,800 rpm and produces torque of 136 N·m (100 ft·lbf) at 6,200 rpm. The ram-air intake on the 2010 model increases power to 117.6 kW (157.7 hp)."
http://en.wikipedia.org/wiki/Kawasaki_1400GTR
Offline katata1100
« Reply #27 on: March 11, 2012, 12:59:10 PM »
'10 bikes got more fluid in the forks for better handling. There were also changes in the brake pads, might be changes in the discs as well.
« Reply #28 on: March 11, 2012, 03:15:50 PM »
You do realize that Wikipedia is user written.  Just because it's there doesn't make it right.  There should be a ram air statement on the 08/09 bikes.
« Reply #29 on: March 11, 2012, 03:50:29 PM »
Well of course I know that.  I even contribute!  But just because it is Wikipedia doesn't make it wrong, either ;)
I haven't seen one... have tried searching, nada.
« Reply #30 on: March 11, 2012, 03:53:21 PM »
C-14's have had ram air since introduction in '07 ('08 model year). Kawasake even used to make a claim as to how much it increased power at some specific speed. I think once you pass 600 MPH the compression ratio also goes up although the rubber air ducts probably swell also....
There was a change.  The 2010+ is a little faster because of a design change to the front that added ram air.  Should be added to the list.  Supposedly a 4.7hp increase at high speed.
« Reply #31 on: March 11, 2012, 04:28:16 PM »
Try reading this....
http://www.kawasaki.com/Content/pdfs/products/concours_QandA.pdf
My goodness, it's an interesting design document.
Which, oh by the way, is linked to in our Interesting Facts area here:
http://www.zggtr.org/index.php?topic=93.0
« Reply #32 on: March 11, 2012, 05:00:43 PM »
Nice read indeed, thanks Sparky!  :thumbs:
« Reply #33 on: March 11, 2012, 08:24:47 PM »
And there it is!
"Q: How much of a difference does the ram air system make?
A: Some of the C14’s impressive power numbers come from its aerodynamics alone. Its ram air system not only provides a five horsepower boost via a supercharging effect, but has other benefits as well such as reduced intake noise."
In a 2008 document.  Thanks
So that leaves the Wikipedia page... hmmm.  I will see if it can be fixed.
« Reply #34 on: March 12, 2012, 04:27:25 AM »
What's funny about that document is the braking write up and linking of the brakes.  They don't link them because it would subtract from the fun in riding the bike.   That guy must have been fired and a less fun guy took over.  So, I can only come to the conclusion that 08/09 owners are the most fun. ;)
« Reply #35 on: March 12, 2012, 04:33:49 AM »
and the fastest.
« Reply #36 on: March 12, 2012, 04:35:03 AM »
Exactly!
« Reply #37 on: March 12, 2012, 10:28:23 AM »
 :thumbs:
« Reply #38 on: March 12, 2012, 03:45:30 PM »
and the fastest.
HA!  You guys just say that because you have the "OLD" model :)
« Reply #39 on: March 12, 2012, 03:58:43 PM »
First Blood was the best of the Rambo movie series, and the first Die Hard was the best of that series too, sometimes sequals just aren't as good...  ;)
