Author Topic: What you guys do to lift front tire off ground to remove it?  (Read 12994 times)
Offline Awaz
Topic
2016 Ducati Scrambler
2008 C14
Re: What you guys do to lift front tire off ground to remove it?
« Reply #2 on: May 17, 2011, 02:49:11 PM »
I have a craftsman atv stand that I put just slightly under the header, which allows me to lift the front wheel off the ground and hold it there.
« Reply #3 on: May 17, 2011, 02:56:42 PM »
1990 Mazda B2600i scissor jack....under the pan lug
Offline Gearhead82
« Reply #4 on: May 17, 2011, 02:58:20 PM »
A handful of throttle and sometimes a little clutch. . .
Oh wait, you want remove the front wheel too. . .
Offline George in N Az
« Reply #5 on: May 17, 2011, 03:04:20 PM »
dedicated bike stand. I have seen the use of a wood block and small car jack to help a little. It will put the weight onto the rear wheel and center stand.
2002 Concours various farkles,
04 Wee Strom - Killer Renthal conversion, Sonic
89 Councours
Offline S.Ga.Rider
« Reply #6 on: May 17, 2011, 03:08:54 PM »
Center stand and front stand.
Offline lt1
  • 2008 C14
« Reply #7 on: May 17, 2011, 03:10:41 PM »
I use a hydraulic floor jack.
Eyes, Brain, Hands.  Repeat.
« Reply #8 on: May 17, 2011, 03:34:38 PM »
I can't tell if this is a joke or not so you are going to get two answers:
1) Smarta$$ed answer: Yes because if you don't, the bike will fall down onto the forks when the wheel is removed.
2) Serious answer: Yes, I am with Clyde and just lift the bike by the headers with a floor jack. It only takes about 10 lbs. of force to make the rear tire touch the ground. If I leave the bike without a front wheel overnight, I put a milk crate under the forks and let the jack down until the fork ends touch the crate and then leave the jack under the bike as well as the milk crate.
Topic
Offline Awaz
« Reply #9 on: May 17, 2011, 03:43:03 PM »
Thanks for the responses. Of course bike will be on center stand and (as suggested by you all) another stand underneath headers :D
2008 C14
Offline gonzosc1
« Reply #10 on: May 17, 2011, 04:51:23 PM »
I think someone said before that you could get the front off without removing the fender. I don't see how though.
I just changed my tires, while I had the back tire off I used a small floor jack under the pipes.  jacked it up just enough to roll the front tire out with the fender still on. put axle back in forks and set axle down on jack stands while I took tires in for changing.
Offline CrashGordon
« Reply #11 on: May 17, 2011, 05:01:52 PM »
I could not get my front wheel off without removing the front fender (at least removing the bolts that hold it on so I could raise it).
I have a Pit Bull front stand left over from my sportbike days and that's what I use.  Tried to use it without putting bike on center stand the first time, but couldn't even get the wheel to leave the ground.  This bike's a LOT heavier than a Ducati.
Offline spotcw
  • It is...what it is
« Reply #12 on: May 19, 2011, 10:07:03 PM »
floor jack under the headers with a block of wood between the metal parts.
« Reply #13 on: May 19, 2011, 10:32:13 PM »
and I do that after taking the rear wheel off so they are both off at the same time.
so much simpler on our fast bikes with race stands though!
Offline nevadazx12
« Reply #14 on: May 19, 2011, 11:39:01 PM »
I use a small cheapo floor jack under the drain plug and a milk crate if it's going to stay on it for a time.  Something else that's handy if you need to raise the bike while on the center stand. I cut a length of 2x4 in half on a diagnal so I created two large wedges.  Now I lean the bike on the center stand and walk it up in the wedges by going back and forth from either side until I get enough clearance so that the rear wheel clears the fender.  Sure beats trying to get the beast on a slab of wood at one time on to the center stand, lots easier on the back.
1986 Connie
1974 BMW 90/6
1964 Triumph T100SC
Offline Tactical_Mik
  • Lamh laidir an Uachtar
« Reply #15 on: May 20, 2011, 04:19:55 AM »
2X10 under the center stand and a floor jack under the header.
T.S.R.
Offline bdhszy1
« Reply #16 on: May 20, 2011, 05:00:49 AM »
 I put big eye screws in the roof rafters and use m/c tie downs hooked to the handlebars. If I use the ratching kind, I can lift the front up high enough to take the wheel off without taking off the fender.
Offline COGnosticat0r
« Reply #17 on: May 20, 2011, 05:48:00 AM »
That is my method also, and I don't think I have to remove the fender, but really can't remember
Jerry Holland
COG 4478
2013 C14
Offline jjsC6
« Reply #18 on: May 20, 2011, 05:51:59 AM »
I've taken the front tire off without removing the fender several times.  No problem at all.  BTW, I use a hydraulic floor jack and a piece of 2x10 under the pipes - and I don't put anything under the center stand.  In fairness, I've always taken the rear tire off first which allows me to jack the front up a little higher (I always take both wheels off so I can take them to the dealer together to have new tires mounted).
Jim
2010 Concours - Sold Feb 2013
Current bikes....
Offline manowarwi
    • Midwest Sport Riders
« Reply #19 on: May 20, 2011, 05:57:29 AM »
I put a 2x10 under the center stand like many have mentioned and then use a fork motorcycle stand (mine is a T-rex, but any should work).  I just had my front wheel off on Tuesday.  I didn't have to fully remove my front fender, but I did remove just the front screws and it tips back far enough to roll the wheel out.
FYI, here is a thread I started about front wheel removal with torque settings and what bolts to remove: http://zggtr.org/index.php?topic=24.0
