Author Topic: What you guys do to lift front tire off ground to remove it?  (Read 13002 times)
Offline Assassin 11B3P
  • The C14 is vastly overrated.
Re: What you guys do to lift front tire off ground to remove it?
« Reply #20 on: May 20, 2011, 08:15:20 AM »
i hire a couple of mexicans. pretty damned cheap.
Please use this forum to demonstrate your own ignorance, unfamiliarity with empirical data, ability to repeat discredited memes, and lack of respect for scientific knowledge. Also, be sure to create straw men and argue against things I have neither said nor even implied. Any irrelevancies you can mention will also be appreciated.
« Reply #21 on: May 20, 2011, 08:22:33 AM »
c14 simplest bike ever to remove/replace front/rear wheels !
Offline SkylineNZ
« Reply #22 on: May 20, 2011, 08:50:34 AM »
This might look a little ridiculous, but it worked.  Rear came off first.  Added the orange ratchet to keep the center stand from flipping back.  Pulled the front fender.  Used the front jack stand.  The weights all on the center stand and the front jack.  The rear car jacks on the swing arm were a safety net.  I don't like pulling one wheel at a time.  :)
Offline jjnorc
  • 2009 C14 Non-ABS. Red.
« Reply #23 on: May 20, 2011, 08:53:49 AM »
I can't tell if this is a joke or not so you are going to get two answers:
1) Smarta$$ed answer: Yes because if you don't, the bike will fall down onto the forks when the wheel is removed.
2) Serious answer: Yes, I am with Clyde and just lift the bike by the headers with a floor jack. It only takes about 10 lbs. of force to make the rear tire touch the ground. If I leave the bike without a front wheel overnight, I put a milk crate under the forks and let the jack down until the fork ends touch the crate and then leave the jack under the bike as well as the milk crate.
+1 here. Floor Jack on the Headers.
Because turning doesn't suck.
« Reply #24 on: May 20, 2011, 12:42:46 PM »
« Reply #25 on: May 20, 2011, 01:27:12 PM »
I wonder how he kept the front wheel on the ground?
