I just picked this post to reply to, not inferring anything
I have 4000 miles on my bike with Maxima Ultima real synthetic. When I change it at the 7500 mark, I'll send a sample in- I'd be real happy to see how it compares to the cheap Rotella group III stuff.
Oil analysis does provide some
very useful information. But only if a baseline is established beforehand. Typically it'd be the 'normal' chemistry of the oil/engine, and how it wears (ie: what shows up in the analysis...
every time).
Consider engines in our typical motor-scooters are basically throw away, so spending $15-$50 on an analysis every XYZ miles might also be considered throw away too
Really, if you watched you graph over time, and suddenly found an increase in steel in the latest analysis, what would you do? Jerk the engine to find out why? And repair it? I kinda doubt it.
Not like we're running a $100k inline 12 cylinder NatGas fired air compressor, nor a $200k+ diesel tug engine. Both hold barrels of $5/qt oil, and both may benefit from an early detection of 'stuff' in the oil.
FWIW, I change oil and filter when I change tires. That'd be about every 10k miles. Done this sixteen times (+/-). Do the math
Having an oil analysis done is a neat farkle though, but kinda moot in my book
Rick
