look closely at the original pic he posted, and zoom it up to max...
I don't argue raising them without letting them come in contact with the risers will be safe, but allowing the forks to fully slide up there without caution, and remain in compression contact on that small concentrated edge seen in the photo, right exactly at the point of the fracture line, and also having that witness mark on the broken handle, is pretty evident.
By the way, I don't believe these are "cast". I am almost positive they are powder metal technology,
but they are Forged, and likely heat treated afterwards... This provides a much higher flow strength, and resistance to deflection in only certain directions, and high compression strengths in others, but given a sharp edge to vibrate against in an area like that, will certainly cause microfractures, and eventual failure.
I pulled and posted a picture from the dudes website showing he had 2" risers installed at one time, and he likely did the lowering of the trees while he had the risers on, then pulled the risers, and re-installed the bars without giving a second look.....possibly even forcing them down with the bolts. We cannot say, but we CAN make educated assumptions on what may of occured.
Nonetheless, if the forks were in thier original position, I'd give it a thought, seeing them sitting as they are, I chalk it up to poor thought process' on installations amd mods.
farkle on dudes...
