Author Topic: Has Anyone pulled the Flies out of a 2011 Concours abs?  (Read 8868 times)
Offline survior
« on: August 17, 2011, 04:22:16 AM »
Hello everyone - I have my new pipe-PC5 and was curious about taking the flies out.  I did it on my 08 and it worked great.  Do not know if removal may cause a issue with anything on the 2011.  Any info would be appreciated.  Thanks
Re: Has Anyone pulled the Flies out of a 2011 Concours abs?
« Reply #1 on: August 17, 2011, 04:44:54 AM »
Affects the traction control I think. Might want do a search on ECU reflash.
Offline CigarSki®
  • Newb again?
« Reply #2 on: August 17, 2011, 04:58:08 AM »
There are integral to the control system. See Fred's videos below.
http://forum.cog-online.org/index.php/topic,28568.0.html
Wayne Sikorski aka CigarSki
2010 ZG1400 - South Jersey
COG 9250
Offline cablebandit
« Reply #3 on: August 17, 2011, 08:04:10 AM »
I pulled them on my 2010, which is the same bike.  No issues to speak of.
Offline Kazairl
« Reply #4 on: August 17, 2011, 08:31:18 AM »
No Issues on my 2010 either. Traction control still works.
Offline Behindbars
« Reply #5 on: August 17, 2011, 11:03:05 AM »
Pulled them on my 2011. Everything still works. No problems.
« Reply #6 on: August 17, 2011, 11:06:46 AM »
« Reply #7 on: August 17, 2011, 06:30:23 PM »
You are partially neutering the traction control when you take out the flies.  Yes, it will still work partially, but the flies are supposedly the most important control is has over the system.  With them removed or disabled, [it is my understanding that] it will greatly diminish the performance of the traction control system on the 2010/2011.
« Reply #8 on: August 17, 2011, 06:34:59 PM »
Not necessarily- traction control works by controlling the secondary 'flies, fuel and ignition. Even with the 'flies removed the ECU has complete control over fuel and that alone is sufficient to reduce power output to zero if the programmers wrote the code that way.
I do not have traction control on my C-14 but am curious as to how it would work with the 'flies removed. There were three posters in a row who claimed T.C. is still effective with the 'flies removed so I am inclined to believe that is the case.
Have you had T.C. fail or work poorly after removing the 'flies?
You are neutering the traction control when you take out the flies.  Yes, it will still work partially, but the flies are supposedly the most important control is has over the system.  With them removed or disabled, it will greatly diminish the performance of the traction control system on the 2010/2011.
« Reply #9 on: August 17, 2011, 06:40:46 PM »
Sorry, I didn't mean to sound too authoritative.  I am repeating an opinion formed from previous postings on various forums, stuff I saw in the factory manual, discussions with my mechanic friend, and some logical conclusions.  I, personally, have zero experience with removing or disabling the secondaries.
I don't doubt the TC still works, I was just asserting that [supposedly] it would not work as well, since the "flies" are an important part of the system.  I better qualified my previous posting.  Thanks
Offline Kazairl
« Reply #10 on: August 17, 2011, 09:38:25 PM »
 To be fair, The number of times the Traction control kicked in between removing the flies and my little canine incident are few. Maybe 2 or 3 times at most. But I do not remember it being much different than before. Most of the times the Ktrac kicks in is slow speed as I try to navigate the mud puddles separating me from the highway. I've only had it kick in a couple times while riding and that was before I pulled the secondaries.
Offline cablebandit
« Reply #11 on: August 18, 2011, 06:54:12 AM »
Mine only kicks in on gravel roads and most of the time I have to intentionally engage it just to see if it actually works.  It works just fine with the flies removed.  Unless you are intentionally trying to flog it the only way you know it engaged is the display flashing and a lack of power momentarily.
Offline stewart
« Reply #12 on: August 18, 2011, 08:35:19 AM »
Beyond the potential impact of traction control, you have to also consider the need to adjust fuel with a power commander to get best performance. Add it all up and the Flash approach is more cost effective, less moving parts and simple.
Stewart
2010 Concours14
COG 9380
Offline Tarheelbob
« Reply #13 on: August 18, 2011, 09:31:36 AM »
The OP already has the Power Commander V. This would be a no-cost modification for him.
Offline Behindbars
« Reply #14 on: August 18, 2011, 03:44:24 PM »
Offline Mad River Marc
  • The Kipass shall inherit the earth
« Reply #15 on: August 19, 2011, 08:57:27 AM »
I would go for the flash myself,  a PC just works inline with the fuel injectors and modifies the pulses, it's an additional link in the chain that adds unnecessary  complexity  (IMHO)
By getting the Guhl Motors flash, they have programmed the system to open the flies pretty much immediately and no extra wiring to worry about and no flies to remove...
Offline koval68
« Reply #16 on: August 19, 2011, 10:02:56 AM »
I agree with you Marc. Guhl re-flash is the route I'll be taking,too.
- Mahatma Gandhi
Offline Kiwi Graham
  • Country: nz
« Reply #17 on: August 24, 2011, 06:17:32 PM »
Anyone know if Guhl Motors still exsists?
I have written to them twice asking about the cost of a re-flash and postage but heard nothing back??
Going on leave in December so could post them my ECU and it could be done and posted back while I'm away but I cant get a reply?
Offline Kazairl
« Reply #18 on: August 24, 2011, 11:11:21 PM »
Have you tried Dynotronics?
Offline Kiwi Graham
  • Country: nz
« Reply #19 on: August 25, 2011, 12:11:38 AM »
No, have you got a web address please?
