So would adding seafoam in the intake be the cure for the carbon build up? I have a friend who swears by seafoam and puts it in the oil gas and intake. Would it hurt the bike to run it in the intake, and where would be the best place to get to the intake.
a couple comments, mind you, they are only comments and not construed as gospel...
In the c10 world, the famous SISF Steve and I both have feelings that in some cases we found degradation of the rubber tips on the float needles of the carbs, specifically found more often on bikes where libberal doses of seafoam, and other "stuff" (B-12 berrymans, etc..) had been dumped in, and let set for long periods of time, in lieu of burning up the complete tankfull it was dosed to. with that said, there are some pretty expensive rubber parts inside this C14, that if this were to be an issue, may render more $$ repair than not.
Running the treated fuel completly out is the main safe bet, not dumping it in and letting it set. I would not like to see fuel pump seals after that happens....
as for "injection" into the running bike i.e. how it's done when cleaning a fuel rail on a car, I don't think we can accomplish this easily, and it is probable needless to do with the injectors anyways, as I have yet to hear feedback on a faulty injector to date...yet.
BUT...
I suppose it would be possible to do a "de-carbonizing" douch, by all rights, if a minimal flow, evenly distributed and metered, could be introduced into the vacume inlets we use for synching, it would effectivly do the trick, with the bike running about 2k rpm, over a period of 5 minutes or so, using the cleaners i noted in a prior posting here... of course you would need a monster fan setup to keep the bike cool during the process, but I have "douched" old carbon fouled car engines both thru intake manifold fittings, and directly thru the carb body.... no difference when trying to de-carbon the combustion chamber.
I do caution though, your post mentions
adding things to the oil.....that would be bad...very very bad.....do not put it in the oil.....
