Author Topic: Flash to pass  (Read 5392 times)
Offline krsron
Flash to pass
« on: July 15, 2011, 03:43:34 AM »
I understand you can alter the flash to pass to toggle through display.  Can anyone explain procedure.
Thanks Ron
Offline jonathan
Re: Flash to pass
« Reply #1 on: July 15, 2011, 08:45:53 AM »
The details were lost in the crash but the basic procedure is to take the instrument cluster apart, solder a couple of wires to the exisiting push button which you then run to the flash to pass button wired in parrallel so that it now duplicates the function of the button on the cluster. If you decide to do it please document it so that we can repost it.
ang
Re: Flash to pass
« Reply #2 on: July 15, 2011, 04:23:54 PM »
I asked the same question awhile ago and never got an answer. I do not feel confident enough to attempt this till I get a more detailed answer. If I remember correctly the procedure was detailed enough so even i could do it.
Offline tundra dweller
  • XLR8
Re: Flash to pass
« Reply #3 on: July 15, 2011, 09:00:20 PM »
It should be easy enough to trace the wires from the selection button to the board.
Most of the work will be tearing the dash apart to get to the board. Nope...I'm not doing it. ;D
"When my time has come I prefer to be in the Saddle rather than the Recliner"
Re: Flash to pass
« Reply #4 on: July 15, 2011, 09:45:22 PM »
I'm interested in this one... :popcorn:
Offline wally_games
Re: Flash to pass
« Reply #5 on: July 15, 2011, 10:47:01 PM »
What's wrong with using the trigger that Kawasaki gives you for toggling through the display functions? Rather use your thumb than your index finger?
Offline C1xRider
Re: Flash to pass
« Reply #6 on: July 15, 2011, 10:53:35 PM »
The 08 & 09's didn't have that button.  They want to add the functionality we enjoy by tying it into the F2P button.
Re: Flash to pass
« Reply #7 on: July 15, 2011, 10:57:32 PM »
Yep! And I never use that flash to pass button...
Offline MrFurious
Re: Flash to pass
« Reply #8 on: July 16, 2011, 02:55:49 AM »
the F2P button is pretty handy for communicating with the driver who just cut you off via morse code.  For instance...
FYYFF
Nice move a-hole
Did you get your license from a Cracker Jack's box
Jim B.
COG #9642
2009 C14 - Black - Non-ABS
Insanity is not as easy as I make it look!
Re: Flash to pass
« Reply #9 on: July 16, 2011, 06:48:06 AM »
FYYFF
Nice move a-hole
Re: Flash to pass
« Reply #10 on: July 16, 2011, 09:46:34 AM »
 :rotflmao: :rotflmao:
Re: Flash to pass
« Reply #11 on: July 16, 2011, 09:53:17 AM »
 :rotflmao: :rotflmao: :rotflmao:
Offline tthompsr
  • 2009 Black Concours
Re: Flash to pass
« Reply #12 on: July 16, 2011, 07:08:23 PM »
 :rotflmao: :rotflmao: :rotflmao: :rotflmao: :thumbs:
Offline McJunkie
Re: Flash to pass
« Reply #13 on: July 17, 2011, 04:27:57 AM »
Here are some photos
Offline GTRrob
Re: Flash to pass
« Reply #14 on: July 17, 2011, 10:23:37 AM »
hmmm...
Offline madcap
  • Only slightly nuts
Re: Flash to pass
« Reply #15 on: July 17, 2011, 10:29:45 AM »
McJunkie - Thanks for posting those - have been wanting to do this for a while! Since I'm assuming this is a momentary contact switch, what does the other side connect to - power or ground? And any info on where it's easiest to access the wires from the handlebar button? I'm sure I can follow them if needed, just wondering if there is an easy access point... Thanks again!
Anything you say, can and will be misquoted and used against you.
_________________________________________________
2009 CR14 - Red (ish)
Offline robbie
  • Tampabay, FL
Re: Flash to pass
« Reply #16 on: July 17, 2011, 02:45:21 PM »
It is a momentary ground. Unfortinently I cant find the pictures I had of it. I did it on mine with a small weather proof switch mounted on the bars but you could use the FTP button if you prefer. You would have to unsolder the wires going to the button and then run one wire from the switch to the instrument cluster and the other wire to ground so that when you push the button it grounds.
2009 Kawasaki Concours 14, 2003 Goldwing, 2002 Goldwing, 2015 F-150, 2018 JK Wrangler, 2002 TJ Wrangler
Offline C1xRider
Re: Flash to pass
« Reply #17 on: July 17, 2011, 03:30:06 PM »
Hmm, I wonder if the High/Low beam switch on the 08/09 could be modified to act like the F2P on the 10/11 (Low beam press hard is momentary F2P).  Then the display mode selector could be added to the finger trigger, without loosing the Flash feature.
The assembly isn't broken down in the parts diagrams, and it's probably not worth $100 to anyone to add the newer style housing.  It would be interesting to know if anyone has looked at that option when they had their handle bar controls apart.
