Author Topic: disabling ABS (08)  (Read 5783 times)
disabling ABS (08)
« on: February 18, 2018, 05:01:58 PM »
I want to put my ZX14 forks with AP Suspension internals on my 08 ABS. THe ZX14 right fork bottom will take some fancy machinest work to mount the sensor. I am tempted to just tuck the sensor up out of the way. I assume this will trigger the yellow light and not effect anything else.
Re: disabling ABS (08)
« Reply #1 on: February 18, 2018, 05:14:38 PM »
IIRC there's been several threads on installing the sensor on zx14 and olins forks....didn't seem too difficult.
« Reply #2 on: February 18, 2018, 06:58:17 PM »
I will search for those threads. But seems like the surface of the fork bottom where the sensor mounts will have to be milled before the holes are drilled.
« Reply #3 on: February 18, 2018, 07:09:42 PM »
Electric die grinder or drill press with a bottom cutting bit?
« Reply #4 on: February 18, 2018, 07:13:43 PM »
« Reply #5 on: February 18, 2018, 08:11:51 PM »
Does not seem like same issue in that thread.
Hope this pic illustrates the problem.
Offline Daytona_Mike
« Reply #6 on: February 18, 2018, 08:57:14 PM »
There have been a few people here  who had that same issue  and they just drilled and tapped and fixed the problem.
I am sure some one must have  some more info to give you. Did you post this  on the other forum?
No way would even think about getting rid  of anti-lock brakes because of an issue like that.
« Reply #7 on: February 19, 2018, 01:06:02 PM »
where did you find that, nothing like it at home depot
« Reply #8 on: February 19, 2018, 04:02:26 PM »
I got a set of burr bits at NAPA. Make sure it has cutting teeth on the bottom...some don't.
search...die grinder bottom cutting burr bit
« Reply #9 on: February 19, 2018, 04:33:09 PM »
Thanks, Ill hit NAPA tomorry
Another question, should I get a cheap die grinder and use my compressor or will a cheap drill press work?
« Reply #10 on: February 19, 2018, 04:38:06 PM »
Two people and the drill press will probably work the best. It should machine easily.
I've got an electric die grinder..Makita.. more useful to me than the pneumatic I've got.
« Reply #11 on: February 19, 2018, 04:50:25 PM »
Thanks.
« Reply #12 on: February 20, 2018, 06:05:14 PM »
Cannot find anything like this at Home Depot, Lowes AutoZone or NAPA. THe guy at NAPA searched his catalgue for 10 minutes and NADA. Going to look on McMasterCarr.
« Reply #14 on: February 21, 2018, 07:02:03 AM »
McMaster Carr will have them but they tend to be expensive.
MSC is much less expensive usually. They will also happily ship but not quite as fast as McMaster (I am w/in one business day of McMaster Carr and they have never, ever, 'missed' in over 30 years of doing business with them- if ordered before the cut- off time, it will arrive the next day).
Try single- ended end mills for inexpensive, end cutting tools. This is a starting place:
https://www.mscdirect.com/browse/tn/Milling/End-Mills/Square-End-Mills?navid=12106240#navid=12106240+4288247969
Let me know if I can be of more help and I can wade through the choices (there are 25,000 listed above) after we figure out what, exactly, you need to do. I have both C-14 as well as ZX forks and so should be able to figure out the right size cutter, length needed and the shank size once I know the opening in your chuck (Easy Bob!).
« Reply #15 on: February 21, 2018, 07:57:39 AM »
Thanks Brian. I had found this at a reasonable price at McMaster
High-Speed Steel Square-End End Mill for Aluminum
Uncoated, 2 Flute, 1/2" Mill Diameter, 3-1/4" Overall Length
$24.
I am in the process of drilling the 12mm center hole for the sensor starting at 1/16. The hard part was securing the fork bottom perpendicular due to the compression adjuster protruding. My pilot hole is not 100% but hopefully close enough.
Once that 12 mm hole is done I will position the sensor and draw an outline where the metal needs to be removed.referencing the attached photo, the sloped surface needs to be flat and slightly recessed I think as in second picture.
« Reply #16 on: February 21, 2018, 09:52:14 AM »
Great Bob.
I have chased tolerances to six digits (English system, millionths of an inch through laser inteferometry) and nothing is ever 100%. Everything that works is always 'close enough'. A human eye can detect amazingly small and accurately given some care; humans can align two parallel rails, 6" long, w/in 0.005" over and over again- it is just amazing. So if you got that fork as close to perfect as your eyes allow, I am sure it is more than good enough. Even the factory fork, along with the sensor, the threads, the slotted plate and everything else will not align to a few thousandths but those inductive sensors are really very forgiving. So I am confident your altered fork bottom will work perfectly as well.
$24.
« Reply #17 on: February 28, 2018, 01:12:28 PM »
Test ride today. Abs light went out soon as underway but came on with first hard brake and stayed on.
Offline Freddy
« Reply #18 on: February 28, 2018, 05:30:26 PM »
What fault code does it give when you retrieve it?
« Reply #19 on: February 28, 2018, 05:37:27 PM »
Getting 43 and 53
