Author Topic: disabling ABS (08)  (Read 5784 times)
Offline Freddy
Re: disabling ABS (08)
« Reply #20 on: February 28, 2018, 05:54:44 PM »
Do you have a gen 1 FSM at hand?
43 = Front wheel rotation sensor wiring abnormal
(wiring shorted or open)
53 = Power supply voltage abnormal
(over-voltage)
The 53 may be a stored old code from a previous time.
« Reply #21 on: February 28, 2018, 05:58:22 PM »
Have the FSM. My zx14 adaption work fell short. Gonna take some more flesh off in the morning.
« Reply #22 on: February 28, 2018, 07:13:45 PM »
Correction: codes are 42 and 52. Sorry for the typo. 52 is undervoltage and 42 is wrong gap.
Offline Freddy
« Reply #23 on: February 28, 2018, 09:07:01 PM »
I think you have the answer.
« Reply #24 on: March 01, 2018, 03:50:49 PM »
SUCCESS. There was no way to accurately mill a measured amount of aluminum to achieve the specified gap between sensor and rotor so I just eyeballed it and was conservative on my first try. error #42 told me I had stopped short. Was too lazy to remove fender, wheel and fork again so I made a nother milling pass "in sirtu" with the milling bit in my two handed heavy duty corded drill. This was harder to control than I expected so I quit after a few minutes/ I guess I managed to gouge, er, mill about .025 in
off. it was ragged but I cleaned it up a bit with a file. Put the sensor on and went for a ride. Voila! The light stayed on longer than usual but after 50 feet it went out and stayed off (except for a few ignition  on and off cycles) for the remainder of my 78 mile ride.  :)
I tried to erase the error codes without success. The procedure seems straight forward enough although in the usual odd wording of the FSM. I may be misinterpreting. Can someone who has successfully erased codes give the repeat the procedure in English?
Thanks
Offline Freddy
« Reply #25 on: March 01, 2018, 04:59:41 PM »
I've done it a few times without trouble.  It goes something like: connect wires for diagnostic modes, turn on ign, then remove jumper earth wire while it's still connected to grey wire and touch to earth for 1-2 seconds 3 or 4 times a second or 2 apart (all within 12.5 seconds) then reconnect to earth, turn off ign, pause, then turn on ign to re-enter diagnostic mode; ABS light should come on, go off, then come on again with no flashing if cleared.  I use a jumper wire that is easily & quickly dis/connected to earth rather than the earth wire/plug with the grey wire.
« Reply #26 on: March 01, 2018, 08:37:17 PM »
Confused. Thought black/yellow wire was ground (earth) Are you disconnecting jumper from black/yellow and touching to frame?
Offline Freddy
« Reply #27 on: March 02, 2018, 05:26:07 AM »
Yes, black/yellow wire is earth but it's too fiddly using it for the specified timed steps required.  I put a jumper wire in the grey wire plug and touch/hold it to a good frame earth as specified - on/hold/off/hold/on/hold/off/etc.
« Reply #28 on: March 02, 2018, 06:03:49 AM »
Got it, Thanks!
« Reply #29 on: March 02, 2018, 04:37:22 PM »
Tried a dozen times with good ground verified by my multimeter, even heated jacket harbess connected direct to battery neg post. Could not erase codes. WTF?
Offline Freddy
« Reply #30 on: March 02, 2018, 05:18:01 PM »
 :yikes:
