Author Topic: [q] c14 '08 airfilter install, what side is up ?  (Read 3721 times)
Offline worker
« on: August 09, 2015, 02:03:28 PM »
Hello,
When replacing airfilter on '08 C14 abs, I noticed that it was installed the metallic side up.
However, in this video
https://www.youtube.com/watch?v=QxDiqMcEaQU
(2011 c14)  the air filter was shown installed metallic side down
what's the right way?
thx
Re: [q] c14 '08 airfilter install, what side is up ?
« Reply #1 on: August 09, 2015, 02:40:50 PM »
FSM says screen side up
...and welcome to the forum
jirod
« Reply #2 on: August 09, 2015, 02:45:44 PM »
If your filter has a metal mesh backing, it goes up to support the filter media against the engine suction. K&N filters like the one he installed do not have a metal mesh backing and you have to go by the slots on the side, like he did on the video.
Welcome to the forum!
Offline worker
« Reply #3 on: August 09, 2015, 08:17:05 PM »
thank you, it is clear now.
quite a chore to get to that filter ! (attaching pic for others who might be new to the bike)
I will get the 67$ K&N, so will follow the slots on the sides.
Offline angelo
    • Some Ride Reports
« Reply #4 on: August 09, 2015, 09:11:37 PM »
Since you have mentioned K and N - any with experience know if it is a direct fit on this bike?  Like exact same as oem replacement?  Thanks
BTW -
I ask, because on some bikes, the size is a little off.
Offline bbhzx12
« Reply #5 on: August 10, 2015, 08:49:24 AM »
I use BMC ever since I put a K&N on my ZX-12 only to fibd it was near impossible to remove to clean it.
« Reply #6 on: August 10, 2015, 10:17:34 AM »
The K&N is a chore to remove. Make sure and use the supplied grease around the rim. They like to stick in there after a while. ;)
