Author Topic: valve check reassembly problem>  (Read 1250 times)
Offline JerBear
« on: June 13, 2015, 02:32:43 PM »
Trying to put it back together I took pictures and have the manual and Fred's videos but I can't figure this one out.  Left hand side, connector for the spark plug wires it has a metal bracket that has a flange that would prevent it from rotation while tightening.  I can't figure out where it belongs? Help if you can.
Jerry
2008 C14 Non-ABS
Re: valve check reassembly problem>
« Reply #1 on: June 13, 2015, 04:03:14 PM »
Jerry
mm mm '08, rear screw of the left hand cover of the reed valve housing....?
maybe?
maybe yess.... 8)
oh the anti rotate tang faces downwards, and also lives on the left side of the cover, the raised section with the rectangular hole to the right and above, with the tongue facing rearwards...
splane that ok fer you?
Offline JerBear
« Reply #2 on: June 13, 2015, 04:31:11 PM »
Thank you again  MOB I owe yah!
2008 C14 Non-ABS
