Author Topic: Bag lock removal  (Read 3052 times)
Offline tthompsr
  • 2009 Black Concours
Bag lock removal
« on: June 22, 2011, 10:49:50 AM »
Anybody here have experence removing the bag locks? If so is there any tricks to save me from completely disassembling the lock assembly? (from what I can see It looks like you have to drill out all the rivets to get the lock cyclinder out).
Re: Bag lock removal
« Reply #1 on: June 22, 2011, 03:23:00 PM »
If I may: what are you trying to do?
« Reply #2 on: June 22, 2011, 03:54:38 PM »
Sounds like he is trying to remove the bag lock.....sorry Martin, too much tequila. :rotflmao:
« Reply #3 on: June 22, 2011, 03:56:30 PM »
Just leave your bags off...............
« Reply #4 on: June 22, 2011, 04:13:05 PM »
Won't they just fall off or get stolen all on their own...  ;)
Offline tthompsr
« Reply #5 on: June 22, 2011, 05:33:34 PM »
I'm trying to replace the mismatched bag locks that the dealer installed on my bike, I have new tumbler's that now match the ijnition and gas tank lock, but I wouldn't let them install the locks because they scratched my bag installing the wrong ones! any help would be greatly appreciated.
« Last Edit: June 23, 2011, 08:19:53 AM by tthompsr »
Offline tthompsr
« Reply #6 on: June 23, 2011, 08:21:44 AM »
bump
« Reply #7 on: June 23, 2011, 09:56:51 AM »
I have switched a bag lock between two seperate bags and IIRC there are 4 bolts that hold the lock/handle assembly to the bag.  They will just pull off of the bag after you remove the bolts.
If you are wanting to remove the actual lock cylinder from the lock/handle assembly then I would reccomend finding a skilled locksmith since the one that I took my lock into said that it would take them around 30 minutes ($70) to switch them between the two.  I decided that I would just leave it the way that I had it.
Offline tthompsr
« Reply #8 on: June 23, 2011, 10:22:33 AM »
Thanks for the reply Jeremy, Yes I'm looking to replace the lock cyclinders, right now I'm carrying 4 keys around and would like to cut that number down, I've had the lock/handle assembly off the bag and from the looks of it everything
is put together with rivets.
