I have found verbiage that states that K-ACT complements the standard ABS.
So, since the point is to provide optimum braking force without locking the wheels up, it makes sense that if the system senses wheel lock in only the front wheel, it would only modulate the front brakes to maintain maximum braking force.
Hehe...yes, you are absolutely correct...but in the video and verbiage, the independent front and rear ABS activity pointed out are on the models that do not have linked brakes, like the ZX10R. When the video gets to the Concours-14, it says that the K-Act ABS module synchronizes all front and rear braking activity...it doesn't mention anything about the ABS acting independently on the front and rear wheels.
On models that have completely separate front and rear brakes, then yes, absolutely, the ABS will work independently.
Don't worry, I'm not saying that you're wrong...since I obviously don't have any evidence to the contrary. The 08-09 C14 models with ABS would have independent ABS actions for sure. If the 2nd gen linked brake models are doing this, then they would definitely have to unlink the brakes at that time, and I've never heard of that before today, that's all;).
Rem
