Author Topic: Water wetter  (Read 8598 times)
Water wetter
« on: June 16, 2011, 09:07:59 AM »
I am trying Redline Water Wetter in both my VFR and my C14 this summer. For the VFR to improve its poor low speed cooling characteristics. For the C14 to decrease the amount of heat coming through the seat and tank.  Redline claimes up to 20 degreef reduction. I can't really tell any definite difference going by the C14 bar guage. For one thing I never paid a lot of attention to the guage as the C14 has always seemed to cool well as apposed to the VFR. Also, I don't have any faith that the BAR guage system is very price or accurate. On the other hand the VFR has a numerical gauge and I definetely see a difference of 5 to 7 degrees lower temperature according to the gauge.
As for seat of the pants (literally), subjective result the C14 seems a little bit cooler in the crotch area. The heat coming from the cowl vents does not feel less, if anything more. To me this makes sense since the only way to make the engine run cooler is to extract heat via the radiator and that heat goes out the cowl vents. This is fine with me as that heat does not bother me.
Offline Pynikal
Re: Water wetter
« Reply #1 on: June 16, 2011, 09:09:38 AM »
i used it on my built civic and it seemed to do the job very well.
Re: Water wetter
« Reply #2 on: June 16, 2011, 09:20:33 AM »
I don't get how this stuff can work. The C14 creates X amount of BTUs in heat right? This stuff claims that it can reduce that heat, where does the heat go?
Re: Water wetter
« Reply #3 on: June 16, 2011, 09:55:50 AM »
Per the Red Line site:
"* Reduces or eliminates bubbles or vapor barrier that form on hot metal surfaces to reduce coolant temperatures by up to 20°
  * Superior heat transfer properties compared to glycol-based antifreeze
  * Compatible with new or used antifreeze (including DEX-COOL and long-life versions) to improve the heat transfer of ethylene and propylene glycol systems
  * Improves heat transfer and reduces cylinder head temperature "
Offline Kazairl
Re: Water wetter
« Reply #4 on: June 16, 2011, 10:24:29 AM »
Step 1 Drain coolant
Step 2 Fill with straight distilled water
Step3 Enjoy A cooler running engine
  Straight water cools much better than a 50/50 Water Glycol mix.  As long as the temps stay above freezing this would be your best bet to make the engine run cooler. Or else use a 70/30 Water Glycol Mix. It won't protect to as low a temp as 50/50 but it will cool better.
Edit: I should add that Water Wetter may have additives that the Glycol also has to prevent corrosion and the like.
Offline Mister Tee
Re: Water wetter
« Reply #5 on: June 16, 2011, 10:31:14 AM »
I was going to say.....
Re: Water wetter
« Reply #6 on: June 16, 2011, 11:23:12 AM »
I just googled this and did some reading. The concencious is that it's snake oil. If you're running 100% water, it MAY help some.
http://www.thetruthaboutcars.com/2008/01/redline-waterwetter%C2%AE-review/
YMMV
Offline lt1
  • 2008 C14
Re: Water wetter
« Reply #7 on: June 16, 2011, 12:01:45 PM »
YMMV
They must have changed the link after you posted it.  What I read was that the author performed a non-scientific test without proper controls and was not impressed.  There was no consensus (assuming that is what you meant) that the product was ineffective, as the comments ran more favorable for Water Wetter than unfavorable.
It is what it is.  If you have a well-functioning cooling system with excess capacity and you are not running on the track (spilled coolant is dangerously slippery, WatterWetter is not), you may not need the product.
« Last Edit: June 16, 2011, 12:51:16 PM by lt1 »
Eyes, Brain, Hands.  Repeat.
Offline Fretka
Re: Water wetter
« Reply #8 on: June 16, 2011, 12:19:40 PM »
WW worked for my 1991 vette but I doubt it will make any diff when it comes to radiated heat from the tank. The only way to fix that (that I know of) is to direct cool airflow to the top of the motor/bottom of the frame and it will exhaust back and down around the swingarm pivot. Definitely works but is a huge engineering job.
Fretka
Re: Water wetter
« Reply #9 on: June 16, 2011, 12:55:21 PM »
Yep, that's what I meant.  :-[
That wasn't the only site I read, there are many and they all pretty much say the same thing.
Re: Water wetter
« Reply #10 on: June 16, 2011, 04:37:21 PM »
The  mechanic who recommeded water wetter to me owned his own shop and ran a motocross team and used it in his race motors. Per my post I can't make any real claims for the C14 due to the vaugueness of the temp guage. But for the VFR I was struggling to keep the gauge below 220 with slow or stop and go riding using Honda Pre-mix. With the Water Wetter I am rarely seeing  more than 198.
Re: Water wetter
« Reply #11 on: June 16, 2011, 05:31:24 PM »
Straight water cools much better than a 50/50 Water Glycol mix.  As long as the temps stay above freezing this would be your best bet to make the engine run cooler. Or else use a 70/30 Water Glycol Mix. It won't protect to as low a temp as 50/50 but it will cool better.  Edit: I should add that Water Wetter may have additives that the Glycol also has to prevent corrosion and the like.
You took the words out of my mouth.  Plain water (distilled, is preferred) performs much better than 50% glycol mixes, which is what is typically used.  Now, running plain water is NOT a good long-term idea- it offers NO corrosion protection and no boil/freeze protection.  However... 50% mixes of glycol are WAY overkill for most people.   The default 50% is down to -38F!!!!  Where I live, it very rarely gets below +20F.  So read the packaging/research for mixing more MORE water and less glycol antifreeze/coolant.
Offline Kazairl
Re: Water wetter
« Reply #12 on: June 16, 2011, 06:13:08 PM »
 Are you using Water water added to 50/50 or just straight water? It is a good improvement either way. Have you checked to make sure your radiator isn't getting plugged?
 For racing Water Wetter plus straight distilled water does make sense. But I'm not convinced on its usefulness on the street.
Offline JetJock
Re: Water wetter
« Reply #13 on: June 16, 2011, 08:42:25 PM »
WaterWetter does work, as do some other products. I run Maxima Koolaide in my race bikes. Your engine will run cooler, but whether you'll be able to objectively prove this, is another matter.
Offline JetJock
Re: Water wetter
« Reply #14 on: June 16, 2011, 08:45:17 PM »
Yeah it works, as someone else posted. We run this in the motocross bikes, where the big thumpers will boil over in a matter of seconds on the starting line. It's been widely proven to improve the cooling in these engines and will work in any water cooled engine far as I can tell. The claims are not bogus.
Offline shiney
Re: Water wetter
« Reply #15 on: June 17, 2011, 11:17:37 AM »
These additives have surfactants in them which lower the surface tension of the water allowing it to make better "contact" and transfer heat better.
Re: Water wetter
« Reply #16 on: June 17, 2011, 11:24:31 AM »
I rate this crap right up there with "Scamsoil"
Re: Water wetter
« Reply #17 on: June 17, 2011, 05:33:26 PM »
It dropped the idle temp of My Jeep from 205 to 195. That is significant, because crawling along in 4lo in the rocks is tough duty, & I can do that with the air conditioner on & not overheat. I pretty happy with that.
Offline Y0ssarian
Re: Water wetter
« Reply #18 on: June 19, 2011, 07:39:11 PM »
Bingo. Fill a glass until it's "too full", or until the surface tension of the water makes the top surface bow outward taller than the top of the glass. Now drip a drop of dishwasher detergent into the glass; the extra water runs out, and the surface of the water is now flat. Without the surface tension the water can't form a meniscus, and on a microscopic level that allows the water to have more contact with the surfaces inside the engine and radiator. More contact means more BTU's transferred per liter of coolant flow, so the engine can run cooler. The C14 has a robust cooling system, so any improvement would be minimal...maybe keeping the fan from kicking on for a few extra seconds. On my '86 1000 Ninja with a borderline cooling system in the Tucson heat, it dropped average temps about 10° across the board. I doubt you'd cool the tank or seat area much, but what the heck...I've been wrong before. Try it, and report back (but be objective!)
Offline JetJock
Re: Water wetter
« Reply #19 on: June 20, 2011, 09:11:07 AM »
Well, you're wrong. Tested in the racing world where 4Stroke motors run so hot you can't sit on the starting line with the engine running for more than a minute. The stuff works. Plenty of independent tests have established this.
"Tested" is different than just having an opinion about something you know nothing about.
