Author Topic: Anyone removed the Cats?  (Read 3982 times)
Offline harry76
« on: July 07, 2014, 05:51:08 PM »
Has anyone tried removing the catalytic converters from the stock pipes?
Offline JerBear
Re: Anyone removed the Cats?
« Reply #1 on: July 07, 2014, 06:14:41 PM »
2008 C14 Non-ABS
Offline rocknrod
  • 2013 C14 - Blue
« Reply #2 on: July 07, 2014, 07:13:25 PM »
In anticipation:
EnVIRONment maaaaan :)
« Reply #3 on: July 07, 2014, 07:23:02 PM »
It's ok if you don't throw the guts in the landfill isn't it?
« Reply #4 on: July 08, 2014, 04:53:08 AM »
I believe that the consensus was that it made little to no difference, removed or not.
Offline Rembrant
« Reply #5 on: July 08, 2014, 05:08:58 AM »
 :goodpost: :hail:
Offline harry76
« Reply #6 on: July 08, 2014, 06:40:44 PM »
Thanks guys, I did do a search but it was tough to find any serious answers on here, there seem to be several who are only here to showcase their superior intellect and end up clouding the threads with BS.
« Reply #7 on: July 08, 2014, 07:14:00 PM »
Like this attempt at humor from another thread, Harry?
harry76
Newbie
Offline Offline
View Profile
 Personal Message (Offline)
Re: Max lowered his bike
« Reply #5 on: May 28, 2014, 02:16:59 pm »
ReplyQuote
Thats to keep the pirates from dropping them when they get drunk.
...or is this  your superior intellect showing through?
Offline harry76
« Reply #8 on: July 08, 2014, 07:23:19 PM »
The difference is that was a comedic thread Mr Pink, it was never meant to be a serious question.
Offline Cuda
« Reply #9 on: July 08, 2014, 07:32:11 PM »
Go to a ZX14 forum you can buy used ZX headers for less than $100. 06,07 don't have cats, I used a 08 paid a welder $50.00 to cut open , remove and weld.
Lots of different slip on muffs, new and used Google is your friend...
Gods waiting room Naples
2011 Atomic  Silver
« Reply #10 on: July 08, 2014, 07:40:17 PM »
I believe Conrad answered your question. I also see that JerBear suggested a thread that might help. Did you read that thread? If you had you would have seen reference to additional threads such as this one... http://www.zggtr.org/index.php?topic=1001.0  It has pictures.
Offline harry76
« Reply #11 on: July 08, 2014, 07:40:38 PM »
Thanks Cuda.
« Reply #12 on: July 09, 2014, 04:56:41 AM »
Superior intellect FTW!
« Reply #13 on: July 09, 2014, 05:12:05 AM »
The C14 boards are rife with 12 year old humor, innuendo, bad taste, BS, and off topic replies.  It's the OP's job to wade through the morass to find the gems, of which there are plenty.  It's all part of the adventure here.  In all seriousness, serious answers are few and far between, but the truth is out there.....somewhere.
As far as the subject on removing the cats, it's really not something done with these bikes on a wide spread basis, so there may not be much out there to find.  I did a search on 'cats' on both C14 boards and quite a few posts came up.  Whether or not they are relevant to what you want to know or not is up to you to decide.   Typically I like to pull the oldest posts first, but that's me.
Offline kwakrider
  • Country: za
  • Black- 2009
« Reply #14 on: July 09, 2014, 05:32:03 AM »
http://
Removed the cats before I installed a full aftermarket system...no gains except quite a bit less heat felt. Full system with PCv/Auto-tune or reflash is the way to go!!  ;) ;)
Offline harry76
« Reply #15 on: July 09, 2014, 03:04:03 PM »
Thanks Gentlemen, I have decided to purchase a header and change it out.
So what is the best tuner to buy or should I get it reflashed?
« Reply #16 on: July 09, 2014, 03:14:38 PM »
If you plan to do any other mods, getting a PC is the best route, based on everything posted I have seen.  And unless you want an autotune model (O2 sensor/etc) expect to need Dyno time and such.  I don't have any interest in performance mods (other than flashing for the flies, which I already did), but if I did, I would go the autotune route.... just seems like it would be well worth the extra dollars (especially compared to how much some other stuff can cost).
