Author Topic: Plug and Play Universal Garage Door Opener Using High Beam  (Read 10370 times)
Offline reh8388
« on: June 24, 2014, 04:52:38 PM »
Hey guys I just finished up a project today that I had been working on. I have a made a plug and play universal garage door opener for the Concours. The system works by double tapping the high beam.
http://youtu.be/B10AKxyxUlQ
Yes, this does function almost identical to the Autoswitch. I designed my own circuit to accomplish this. A double tap activates the opener for about 1.5 seconds. If you tap it 5 times the opener is activated for about 30 seconds which allows the opener to be programmed. The one I have made comes as a  complete kit which plugs inline with the high beam relay without cutting any wires and is mounted under the top fairing. The system clones your opener and doesn't require you to sacrifice an opener remote. The system can also be reprogrammed very easily, something that was important to me since I move every year or two.
If this is something you guys would be interested in I can probably sell a few if there is enough demand. I would estimate the price to be around $90 per unit.
The installation is pretty straight forward and should only take 10-15 minutes. Note: The connector and wire colors will change for any final versions of this. I used bits and pieces I had laying around for this prototype
The first step is to remove the 3 bolts holding on the top plastic tank cover. (08-09 will vary some)
Next you will take the module and peel the backing off the dual lock.
Take the unit and firmly stick it to the underside of the front right fairing (dash?). I would clean the area before trying to stick this in there. Press it firmly for 15-30 seconds and will stay put.
Slip the high beam relay and its boot off the tap it is mounted on by pulling it towards the front of the bike. Roll the bottom of the rubber boot up slight and unlug the connector. (This should be a brown connector)
Then simply connect the brown bike connector the garage door opener harness and the garage door opener harness to the high beam relay.
Tuck the harness away...
Put the cover back on and it is all done.
To program the unit, you turn the bike on and just tap the start button (the headlight must be on). Tap the high beam 5 times rapidly and then while holding your current garage door remote over the top fairing (where the new unit is mounted) press and hold the button for your current opener remote for approximately 30 seconds. That is all. I will most likely add an LED indicator to let you know once the opener is programmed.
« Last Edit: June 25, 2014, 05:45:59 AM by reh8388 »
2011 Kawasaki Concours
Re: Plug and Play Universal Garage Door Opener Using High Beam
« Reply #1 on: June 24, 2014, 06:48:51 PM »
That is pretty slick.  I just wish my garage had more room.... I can only fit the G37S in it, no room for the Concours :(  At least I gave it a fairly nice home: http://www.cycleshell.com
Offline Jaxter
« Reply #2 on: June 24, 2014, 08:20:14 PM »
can you make a series of pictures showing the installation process...I want one
I've Never Had A Better Day
Offline udoggie
« Reply #3 on: June 24, 2014, 10:47:36 PM »
For what it's worth, I use a Flash to Pass  http://www.f2ptechnologies.com/
I have it mounted right next to the headlight relay under the plastic cover on the front of the gas tank.
A double flash of the high beam, and the door opens/closes.
My wife would come out shooting if I were to try something like
Automatic Motorcycle Garage Door Opener
  -Jeff
Aloha, OR.
« Reply #4 on: June 25, 2014, 04:07:04 AM »
Offline reh8388
« Reply #5 on: June 25, 2014, 05:25:01 AM »
Jaxter I will update my original post at the top with the information you requested. Let me know if there is enough information there for you.
Offline ljcorby
  • COG#: 9359
« Reply #6 on: June 25, 2014, 05:37:43 AM »
I would be interested as well.  Thanks.
10 Kawi Concours 14 ABS
« Reply #7 on: June 25, 2014, 06:44:41 AM »
I've tried the system referenced in udoggie's video. Doesn't work at all.
« Reply #8 on: June 25, 2014, 07:15:54 AM »
I could try honking til the cows come home and it wouldn't work for me and then I'd probably be cuffed on the head as well for my troubles.
« Reply #9 on: June 25, 2014, 08:19:08 AM »
No soup for you.
Offline JoeRau
« Reply #10 on: June 25, 2014, 08:39:29 AM »
That would be a nice option.  I went the cheap route and picked up http://www.chamberlain.com/clicker-and-accessories/garage-door-controls/chamberlain-keychain-remote-control at a local store.  I used double sided tape and tapped it to my C14 FOB, and keep them in a zipped pocket in my jacket.  Sometimes I hit the button while still moving on the bike, but usually stop first in the driveway.
2012 C14.  Black
COG member 10990
Offline Jaxter
« Reply #11 on: June 25, 2014, 10:18:55 AM »
excellent instructions and pictures...it looks like something even I could do without taking it to a mechanic...now ho do I order one
Thanks
Offline reh8388
« Reply #12 on: June 25, 2014, 12:37:57 PM »
Thanks
Hey Jaxter,
I think for now I will take people at their word if they say they are going to buy one. It will probably take me 2 weeks to put a few together. Ideally I would have 5 definite purchasers before I get everything together for a build, but I think with 3 I can justify it.
Once I have them built and tested we can either arrange payment via a check or PayPal and I will ship the unit out once I receive payment.
« Reply #13 on: June 25, 2014, 12:57:34 PM »
  -Jeff
I can't tell if that's a wife or daughter, but either way gonna cost ya a helluva lot more than $90  :)  :'(  :P
Offline JoeRau
« Reply #14 on: June 25, 2014, 01:49:21 PM »
I saw a BMW emblem there.  He can afford it.
2012 C14.  Black
COG member 10990
Offline Dan Forker
« Reply #15 on: June 25, 2014, 04:18:02 PM »
What if you have a rolling code door opener. Your description seems to be applicable to a standard opener where you can just hold the original one close to the new opener and let the two sync, but my garage door requires that + taking the door opener through a sequence. Does your opener work with rolling code openers also?
Fork
Offline reh8388
« Reply #16 on: June 25, 2014, 04:19:55 PM »
Fork
Fork,
Great question! These DO work with rolling code! Like you said, you would hold your remote near this, and the "learn" the new remote to your opener.
« Reply #17 on: June 25, 2014, 04:55:42 PM »
So might the neighbors :)
« Reply #18 on: June 25, 2014, 05:00:48 PM »
Hmm.... I don't think it is possible to "learn" a rolling code by just listening to it... that is the whole point of rolling codes (to preventing learning it from listening/eavesdropping).   There is a non-transmitted "seed" that is used to pick a different code each time the button is pressed, eavesdroppers would just see randomness.  So each side (transmitter and door opener) must know this seed (for lack of a better term).
Offline reh8388
« Reply #19 on: June 25, 2014, 05:04:00 PM »
Maxtog, if you continue reading, I stated that once you have held the original remote next to the module you then have to "learn" the remote to the opener. You still have to hold the original remote to it to learn the frequency and code type.
So again, this DOES work with rolling code.
