Author Topic: Adding a glove box?  (Read 5146 times)
Offline pat8228
Adding a glove box?
« on: May 17, 2014, 09:01:55 AM »
Can a glove box from a 08 or 09 be added to a 10 or newer? I'm getting ready to buy a newer concours and would like to add the extra glove box if it's possible. Any ideas on this?
Thanks
Offline mvjr1904
Re: Adding a glove box?
« Reply #1 on: May 17, 2014, 10:49:08 AM »
2011 Silver C14 - Fastest
2002 Silver C10 - Fast
Offline whatcom
  • Bellingham, WA
« Reply #2 on: May 17, 2014, 12:52:22 PM »
Did this as soon as purchasing a 2012, had an 08 before and missed it. Went online to a discount Kawaski parts house (usually about 40% off list) and went through their diagrams and ordered all the parts, was less than $200. Had to dremel the pan to fit over the ABS lines, and hammer them down a "little flatter" but works great! Also some little tabs on the sides that had to be dremeled back and new holes drilled. In the end, it looks factory, very pleased.
2013 ZX14r white abs no-flies, scottoiler
2012  C14 Arabian red
Full AreaP ZX14 TB's PCV with dyno map for TB's Rostra CC, W&S remote, A&R HID, Kawasaki trunk with SW-Motech rack, 08/09 storage compartment
Offline whatcom
  • Bellingham, WA
« Reply #3 on: May 17, 2014, 12:54:06 PM »
Oh, forgot, took all the relays that were there and stuffed them behind the other glovebox on the left side.
Offline Spackler
« Reply #4 on: May 17, 2014, 06:10:49 PM »
I have an '09 and want to remove tbe glove box and replace with the plain cover, in order to add AST pullback risers. I just havent gotten around to ordering the parts. That site with the 40% discount on parts would help if you could post a link.
Its my understanding that you need the cover, as well as the bracket under the cover and/or glove box. The brackets differ between the 08/09 models and 10+.
Offline pat8228
« Reply #5 on: May 17, 2014, 07:25:07 PM »
Thanks for everyone's help.
Offline whatcom
  • Bellingham, WA
« Reply #6 on: May 19, 2014, 09:54:06 PM »
Powersports warehouse is one, too bad you two guys could not just swap parts!
Offline garfield1974
  • Country: hr
  • Kawaski GTR 1400 2008
« Reply #7 on: May 19, 2014, 10:56:54 PM »
Sorry for "stealing" the topic but I could not find answer on couple of questions:
1. Can left side top fairing with glove box of model '10 onwards be fitted on the '08 model without mayor modifications ?
2. Did anybody did it ?
3. Is there topic on that subject that I missed ?
Thanks in advance
Gordan
Offline reh8388
« Reply #8 on: May 20, 2014, 02:39:01 PM »
Search is your friend
http://www.zggtr.org/index.php?topic=10955.msg133845#msg133845
Except most of the image links are dead so the threads that almost everything links to isn't of much use.
2011 Kawasaki Concours
« Reply #9 on: May 20, 2014, 02:49:28 PM »
Yes, it's doable. You'll have to relocate the relays under your cover and replace that bracket with the first gen piece. I went the other way because I found that little toaster oven useless for all practical purposes.
Offline JS_racer
« Reply #10 on: May 21, 2014, 05:23:54 AM »
damn, how crazy are those pullback risers to remove the glove box.
Offline Spackler
« Reply #11 on: May 21, 2014, 08:19:57 AM »
I've never used the glove box for more than a sunglass case. Much rather have more comfort. I can always add a tank bag, it'll be soft and sit back enough for the risers to clear.
Offline JS_racer
« Reply #12 on: May 21, 2014, 06:51:50 PM »
Do they interfere?  Don't get it.  Sorry  must be slow here.
Thanks
Offline Spackler
« Reply #13 on: May 21, 2014, 07:52:09 PM »
Thanks
Yeah, the tank top box on the '08-'09 prevents the pullback risers from being used. They work with the 10+ models without the tank top storage box. If I remove the box I can use the risers on my '09.
