Author Topic: Those who have installed HIDs, where are you putting the ballasts?  (Read 2091 times)
Offline copdocpvd
I got a new HID kit for my 2013, am curious as to where you guys are putting the ballasts so they are secure and reasonably out of sight.
Pictures a plus
P
Re: Those who have installed HIDs, where are you putting the ballasts?
« Reply #1 on: April 28, 2014, 03:30:20 PM »
I mounted mine on top of the rubber air intake tubes on each side. Just loosely tie- wrap them so they do not fall out; any significant pressure on the tie- wrap will cause the intake tubes to crush. Actually, my ballasts are stacked with my Power Commander, the ignitors for the HIDs and a couple of other things. The C-14 is tight on room....
Pictures a plus
P
Offline copdocpvd
« Reply #2 on: April 30, 2014, 08:49:47 AM »
Thanks, Brian
Offline lonekazoo
« Reply #3 on: April 30, 2014, 10:26:45 AM »
Here's a nice write-up with pictures courtesy of A&R that has been posted elsewhere on the forum.  I did mine slightly different (on the left side, I velcro'ed the ballast to the outside of the fuseblock).
http://www.aandrmotorsport.com/directions/concourshidinstructions.html
« Reply #4 on: April 30, 2014, 03:50:50 PM »
That is the brand I purchased and the instructions I used to install it.
Offline overlord
« Reply #5 on: April 30, 2014, 09:46:21 PM »
  A-1 setup        love the beams  say " LazerBro's "  let there be light. :cool:
