Author Topic: How to save windshield positions?  (Read 3309 times)
Offline gnuse
« on: April 25, 2014, 08:18:55 AM »
I would like help finding instructions for saving windshield positions in the manual. Thanks.
"God does not deduct from one's time on Earth, that which is spent in the air."
Offline udoggie
Re: How to save windshield positions?
« Reply #1 on: April 25, 2014, 08:26:19 AM »
There is no option to save the current position, however in the setup menu on the display, you can set the position that will it will be set to when you turn on the key.  It's 1 thru 5 I believe.
Just cycle thru the options on the setup screen to find it.
Jeff
Aloha, OR.
Offline gnuse
« Reply #2 on: April 25, 2014, 08:35:01 AM »
Thanks. I found it. I am always amazed at the lack of table of contents. For some reason that setting was lost when changing battery.
Offline copdocpvd
« Reply #3 on: April 25, 2014, 08:53:57 AM »
dumb question, how do you access the setup screen?
Offline petepro
« Reply #4 on: April 25, 2014, 12:10:24 PM »
To access the setup you push and hold the odometer button and the button below it.
After holding for a couple seconds it will enter the setup menu.
One button will then cycle the selection and the position of the cursor.
It takes a couple tries to get it in the right order.
Pete
2012 Concours 14abs - 2013 - Current
2002 BMW R1150R - 2012-2013
1995 Honda 750 Nighthawk - 2001-2009
1984 Suzuki GS1150ES - 1987
Offline copdocpvd
« Reply #5 on: April 25, 2014, 01:22:03 PM »
thank you
« Reply #6 on: April 25, 2014, 04:47:29 PM »
Yep, when you change the battery it will lose that, and the clock, and both trip meters, and several other things.
And the "memory on start" for the windscreen is only on 2nd gen C14's (you don't list in your signature or Avatar what color or year or gen bike you have... but I will assume it is 2nd gen)
« Reply #7 on: April 26, 2014, 03:23:43 AM »
It's annoying the extents the manufacturers go to in order to save some pennies. A capacitor would have enough juice to power those things for some time, I'm sure.
« Reply #8 on: April 26, 2014, 05:42:13 AM »
Indeed.  And it is nothing new.  I have had devices from 25 years ago that would remember settings for 10 to 60 seconds.  Nowadays, they could just use flash memory or static RAM, which is 1000 times cheaper than just 10 years ago... they would only need a few hundred bytes... maybe half a dollar?
« Reply #9 on: April 26, 2014, 06:23:23 AM »
If it really bothers you, a couple of jumper wires and a nine volt battery will fix it while you change the battery.
