Author Topic: Leaking valva cover gasket ?  (Read 2523 times)
Offline phoneman
« on: October 05, 2013, 06:45:30 PM »
  I've been smelling a little oil burning smell coming off my motor everynow and then.
  Couldn't see any drips or burnt spots on the headers with all the tupperware on so I pulled the plastic off the right side to have a look.  Been wanting to look in there anyway.
  Looks like the valve cover is seeping above the 2 middle cylinders.  Not dripping but just enough to make the odor I've been smelling.
  I bought the bike--2009 with 17500 miles--a couple of weeks ago.  It also has 2 years left on the extended warranty.
  It will be due the valve check in about 5000 miles.  What are the odds of getting some of the labor charges dropped if I take it in for warranty work and get the valve job done at the same time ?
  Especially since they will have to do most of the work just to get to the valve cover.
  I also have a low battery warning in the rear tps that pops up every now and then which the previous owner told me about.  The dealer already said they would replace it.  I'll take care of that when I have a new rear tire mounted--which won't be long.
  I fully expected to have to do some of these things so I'm looking forward to getting everything in good working order.
  On a positive note--My Kipass is working great.  All I have to do is remember where I put the fob.  Thinking of just having one of the fobs surgically implanted so I'll never be too far away from it's awesomeness.  Kinda like my blankie when I was a little crumbcruncher.
Offline connie14boy
Re: Leaking valva cover gasket ?
« Reply #1 on: October 06, 2013, 01:50:35 AM »
Sounds as serious as a leaking vulva cover! Better see the doc.
Offline Makz58
« Reply #2 on: October 06, 2013, 07:23:55 AM »
Sounds like your cam sensor o-ring not your valve cover I could be wrong....but do a search lot of information on it.
C-14 2010
Offline blue14
« Reply #3 on: October 06, 2013, 09:15:39 AM »
Isn't that the bitch?  :rotflmao: :rotflmao:
2010 C14, 2007 ZX14,  2004 KTM 300SXC
Offline rush2112
« Reply #4 on: October 07, 2013, 11:30:44 AM »
Took them two times to fix my 2009. Here's the original thread:
http://www.zggtr.org/index.php?topic=11961.0
"A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed
Offline BruceR
« Reply #5 on: October 11, 2013, 11:09:14 AM »
Valva cover?  Sheeza Italiano, no?  Thissa leaking oil, sheeza making me crazy.
Offline SVonhof
  • 2009 C14
« Reply #6 on: October 11, 2013, 01:15:38 PM »
Mine turned out to be the valve cover gasket and not the cam sensor o-rings according to the dealer.
Scott
