Author Topic: What's needed for a valve adjustment?  (Read 3036 times)
Offline theAmazingKickstand
« on: August 16, 2013, 11:55:00 AM »
So my factory repair manual just came in and I'm ready to adjsut valves.
Other than shims what are all the gaskets, o-rings, other parts, do I need to order and have in front of me? I want to get this done in one weekend without having to go to a dealer for emergency parts.
Thank you!
Offline Tarheelbob
Re: What's needed for a valve adjustment?
« Reply #1 on: August 16, 2013, 02:38:37 PM »
Let's see: I put a new valve cover gasket on. Old one looked find, did it for mental insurance. You will need a few new shims if you find any out. Hopefully your local dealer stocks them. Many Kaw dealers don't. Good news is that Honda valve shims are readily available at most dealers and are a direct fit.
Other than that, just some patience, good instructions, and a good torque wrench.
I have the full Service Manual, but couldn't have done it without Fred's excellent C-14 maintenance videos, [urlhttp://www.angelridevideos.com/concours.html][/url]
Good luck!
« Reply #2 on: August 21, 2013, 11:48:31 AM »
Thanks so much. I will buy a new valve cover gasket. Does anyone have a link to the O-ring that supposedly leaks? I don't know the part number or what is called.
Offline gildaguz
« Reply #3 on: August 29, 2013, 07:40:19 PM »
http://www.procaliber.com/oempartfinder.htm?aribrand=KUS#/Kawasaki/ZG1400B9F_Concours_14_(2009)/FUEL_INJECTION/ZG1400B9F-2009/I14I1487E15301
92055 camshaft sensor O ring in this diagram need 2 of those
2009 Non ABS Concours Black
2004 Honda Shadow  Sabre 750
1979 Suzuki 185 all terrain
« Reply #4 on: August 29, 2013, 10:13:41 PM »
« Reply #5 on: August 30, 2013, 05:13:51 AM »
you may find this interesting
http://www.advrider.com/forums/showthread.php?t=435765
Nice link Steve.  I don't have 11 hours to spare so when the time comes, $500 is going to get spent.  Yes, that is what the local speed shop charges.
Offline sherob
« Reply #6 on: August 30, 2013, 07:54:31 AM »
Might as well do the plugs and air filter while you're in there too...  8)
Rob
« Reply #7 on: August 30, 2013, 01:35:08 PM »
this has been a sticky here for a while....
http://www.zggtr.org/index.php?topic=13866.0
or, you can buy the OEM one for $4+ each, and it will leak again....
I have a bunch, follow the directions...and 2 will be on the way to you. ;)
