Author Topic: Fast corners leave me shaking my head  (Read 8562 times)
Offline PlaynInPeoria
« on: August 12, 2013, 08:43:08 AM »
It seems like I have developed a bit of a weave. It used to be ok, but now when I am leaned over and going fast, the head shakes a bit, not really quicky like a tankslapper, but enough to be distracting.  Fairly new Pirelli Angel GT's on the bike, maybe 3k on them.  I was going to increase my front rebound damping, but it was nearly maxed, so I backed it out to 5 clicks out.  This didn't seem to help.  I backed off my rear preload to slow down the steering, this didn't help either. Maybe I should have put the front rebound back where it was and seen what changing only the rear preload.  I prefer to change only one thing at a time and see how it goes, but in this case, I made a mistake and forgot to put the front rebound back before changing the rear preload.
My tire pressure is pretty low (38/35, I can't remember which is front and rear), but is SUCH a pain to change. I bought some of those valve stem extenders which you screw on, change pressure, then remove. I will try to bump the cold pressure up to 42 on both and see if this helps.
I am open to other suggestions. Thanks for your input.
Thanks
Re: Fast corners leave me shaking my head
« Reply #1 on: August 12, 2013, 09:03:37 AM »
I am really of no use when it comes to the mysteries of suspension setup.  But one thing for sure- before you go making changes and such, you really should get the tires back to around 42/42.  38 is 10% off but not terrible.  35 is really pushing it- you should probably be getting an alert on low pressure at 35.  (Good way to wear out your new tires!)
Offline PH14
« Reply #2 on: August 12, 2013, 09:16:25 AM »
I agree with Max, the C14 is a heavy bike. Start with the recommended pressure before trying to adjust anything else. My C14 has never acted like that in a corner.
Offline CIG4R
« Reply #3 on: August 12, 2013, 09:42:45 AM »
My connie seems to be the most tire pressure sensitive for handling bike I've ever owned.
« Reply #4 on: August 12, 2013, 10:38:33 AM »
I had it apart for a while while doing the brake unlinking. I got lazy, I was riding the FZ1, which I hadn't ridden much except for our Sunday morning hooligan rides, I had forgotten how much fun that bike is. I always seem to ride the C14 because it's easy with all the storage and they have nearly identical levels of performance despite having totally different feel.
Anyhoo, I bolted it back up from the brake unlink and fired it up, looking for warnings on the dash etc.  Then I dropped it in gear on the center stand and ran it up to 105 or so indicated and ... I'm kidding. I did put it in gear and spun it a bit in 1st and 2nd at low rpm just to see if the traction control would be ok. Then I take it for a spin nice and easy up and down my street, all is well so I take it for a slow ride. 10 minutes into it and I get this massive OMG warning I had never seen that totally freaked me out for the first 5 seconds, all it was was low tire pressure.  32 is apparently the point at which it warns.  That's when I discovered how hard it was to put air in these tires, what a pain in the ass!
I will throw some air in the tires and see what happens and report back.
Offline clogan
« Reply #5 on: August 12, 2013, 11:37:28 AM »
Adding air is easy; it's getting a pressure gauge on the stem that's tricky!
2010 Neptune blue C14
2009 blue KLR
2013 DRZ400
Offline Daytona_Mike
« Reply #6 on: August 12, 2013, 03:03:25 PM »
This is what I use.  Seems easy enough.
http://tinyurl.com/lxmhfk9
You may have loose head/stem bearings. Have you checked?
Offline wroman
  • 2012 C14
« Reply #7 on: August 12, 2013, 04:57:43 PM »
I have a very standard floor pump that is a piece of cake.
I always wanted to be somebody......I guess I should have been more specific.
« Reply #8 on: August 12, 2013, 05:23:41 PM »
White cake with white icing?
Offline Arata
« Reply #9 on: August 12, 2013, 05:26:37 PM »
2014 V Strom 1000
2008 C14
2004 ZRX1200R
1993 GSXR 1100
« Reply #10 on: August 12, 2013, 05:27:53 PM »
racist!
OK fine-  "European American cake with European American icing"
« Reply #11 on: August 12, 2013, 05:30:46 PM »
 :rotflmao: :rotflmao: :rotflmao: To both posts.
« Reply #12 on: August 12, 2013, 05:32:26 PM »
And this is one of the reasons I like it here so much.  I can laugh my ass of with abandon at least once a day.   :finger_fing11:
Offline pistole
« Reply #13 on: August 12, 2013, 05:34:43 PM »
+1 on the pressures being brought up to 42.
as for the mid corner head weave : used to have it too . Until I learned to relax on the bike and ride it properly.
« Reply #14 on: August 12, 2013, 05:37:40 PM »
The problem with this issue is that it virtually could be anything in the front end from wheel bearings, tires, suspension set up, air pressure, handle bar pressure....  It's a maddening problem to diagnose.
« Reply #15 on: August 12, 2013, 09:15:05 PM »
But of course.  42 is the answer to the ultimate question of life, the universe, and everything.  It should certainly be adequate for C14 tires.
Offline texrider
« Reply #16 on: August 12, 2013, 09:31:03 PM »
Lack of preload on steering neck bearings.
2014 Valkyrie
Offline Gsun
« Reply #17 on: August 12, 2013, 09:56:21 PM »
Try Murphs 90 degree valve stems at the next tire change.
http://www.murphskits.com/catalog/product_info.php?products_id=494
« Reply #18 on: August 13, 2013, 04:46:21 AM »
So, I should have retired at 42?
« Reply #19 on: August 13, 2013, 04:48:43 AM »
 :thumbs:
