It seems like I have developed a bit of a weave. It used to be ok, but now when I am leaned over and going fast, the head shakes a bit, not really quicky like a tankslapper, but enough to be distracting. Fairly new Pirelli Angel GT's on the bike, maybe 3k on them. I was going to increase my front rebound damping, but it was nearly maxed, so I backed it out to 5 clicks out. This didn't seem to help. I backed off my rear preload to slow down the steering, this didn't help either. Maybe I should have put the front rebound back where it was and seen what changing only the rear preload. I prefer to change only one thing at a time and see how it goes, but in this case, I made a mistake and forgot to put the front rebound back before changing the rear preload.
My tire pressure is pretty low (38/35, I can't remember which is front and rear), but is SUCH a pain to change. I bought some of those valve stem extenders which you screw on, change pressure, then remove. I will try to bump the cold pressure up to 42 on both and see if this helps.
I am open to other suggestions. Thanks for your input.
Thanks
